Schumacher Corner
#7996
Leadfoot:
1) Not a big difference in handling. The inboard toe will also change the wheelbase, slightly, since in changes the angle of the arm.
2) You pretty much need to set the hubs in the middle or the wheels will rub the arms. Some people are cutting off the excess insert that sticks out of the hub and just using spacers to center it. Also, you can use calipers, measuring from the arm to the hub before you tighten the screw.
3) Adding spacers to the ballstud will alter roll center and camber change. I will generally add spacers to free the rear end up a little, off power.
4) You can safely remove the rear and the upper front tensioner and it will free up the drive train quite a bit.
#7997
Mo: Thanks for the great info -- that helps a lot!
#8002
What happen to the chit chatter ?
Did you guys get scared?
Hey Matt, Yokomo rules..lol
#8004
#8005
Originally posted by Matt Howard
I heard stlnlst is gonna DOMINATE novice sedan at the regionals, there's this 7 year old kid that's pretty fast though but stlnlst is gonna steal his lunch money before the mains so he's too scared to race.
#8008
Setup Sheet
Hi all,
Sorry for something that you guys have probably provided many time in the thread but i'm looking for any setup sheets you may have for your MI2's. I've been sticking with the original Mi for a while but just bought the MI2 and wish not to spend as much time tunning that car as i did with the original car.
BTW. I noticed in my kit the pulley mounts for the spur gear both said 20 but the instruction manual gives me the impression that one should be 17. Am I wrong about this and if not who do I contact to get me a 17 because two 20's obviously wont work.
See you at superrior hobbies sunday.
THanks,
R.
THanks,
R.
#8009
You can find setups at www.gearchart.com and I have a couple setups at www.mo-net.ws . Yes, you should have a 17 and 20 layshaft mounts. Call Schumacher USA (813 889 9691) or e-mail [email protected] or [email protected]
#8010
talk about quick! thanks dood
