Serpent 811 Cobra Buggy 2.1
#2507
With those screws, tihgren them just enough to come on contact with the OD of the bearing. You don't want to hinder the bearing.
#2508
What are you guys running for clay loose track on the diffs? Is 5-7-3 too loose?
Also on the suspension inserts, 2U-2D for front and 6U-6D rear seem to be ok?
#2509
Hi,
Has anyone tried to fit the srx8 wishbones on the 811 2.1?
#2510
#2511
#2512
On the V2 uprights SER600476, which is left and which is right? On the 2.2 pdf they say to use the right on the left side of the car and the left on the right.
https://www.serpent.com/xcart/serpen...ggy_GP_2_2.pdf
As these have no markings, which is which?
600476 Upright buggy 1/8 V2 (2) NOTE: the upright v2-R must be used on the Left side of the car, and the upright v2-L on the right side of the car.
#2513
I also took measurements between the 811 vs SRX8 wishbones. I do not think they would work, unless you manage to file enough on the SRX8 to match the 811
Sorry for the bad light on some of these pictures, but you can see the difference on the mounting points. Personally I do not think it is worth going through all that trouble in trying to make them fit.
#2514
Looking at the pictures its a no brainer. Not worth the effort. Thanks a lot Sebtarta for pictures and go through! Doc
#2515
#2516
If it would stop raining during the weekend and rain during the week, I might be able to run the car!
#2517
Well I managed to drive the car on Sunday. YAY It was fun, running like a champ. Many crashes, no injuries. Any recommendations on clutch springs for clay low grip?
Does anyone have any 13T (non)vented clutches to off load? If so let me know, thank you
#2518
I did something last night...So I got fed up in cutting the lexan for the mud guards. I went ahead and bought some DE Racing Mud Guards for an HB
Had to make the hole for the screw that matches out suspension arms, fit [AceVentura]Like A Glove[/AceVentura]
These fit the SRX8 cars as well.
I added some stickers for the extra 2.5s quicker until I roll over and crash and the bling factor is gone.
#2519
#2520
They fit the SRX8e as well with no issues.
