Serpent 811 Cobra Buggy 2.1 >
Like Tree10Likes
Old 09-17-2018, 10:15 AM
  #2506
CBren32's Avatar
Originally Posted by Chad Millikan View Post
We all just run two screws, one on the top and the other on the casecase . I always switched mine out for regular hex head screws too, rather than a Phillips. Done get discouraged, keep asking away . we'll get you squared away
Thanks so much for taking your time to help, brother. Really appreciated over here, I am sure I'll be back soon with more questions in the near future. 🤣👍
CBren32 is offline
Old 09-17-2018, 03:16 PM
  #2507
Chad Millikan's Avatar
With those screws, tihgren them just enough to come on contact with the OD of the bearing. You don't want to hinder the bearing.
CBren32 likes this.
Chad Millikan is offline
Old 12-28-2018, 03:50 PM
  #2508
What are you guys running for clay loose track on the diffs? Is 5-7-3 too loose?
Also on the suspension inserts, 2U-2D for front and 6U-6D rear seem to be ok?
sebtarta is offline
Old 01-17-2019, 01:33 AM
  #2509
Hi,
Has anyone tried to fit the srx8 wishbones on the 811 2.1?
Docbenson is offline
Old 01-17-2019, 10:13 AM
  #2510
savage24x's Avatar
Originally Posted by Docbenson View Post
Hi,
I have not seen anyone try yet, no.
savage24x is offline
Old 01-17-2019, 03:38 PM
  #2511
Hi,
From looking at the manuals, it looks possible. Inner hinge pins are the same and outer are same on rears, also same length driveshafts .Just use the srx8 casters and steering block
savage24x likes this.
Old 01-17-2019, 05:32 PM
  #2512
On the V2 uprights SER600476, which is left and which is right? On the 2.2 pdf they say to use the right on the left side of the car and the left on the right.
https://www.serpent.com/xcart/serpen...ggy_GP_2_2.pdf
600476 Upright buggy 1/8 V2 (2) NOTE: the upright v2-R must be used on the Left side of the car, and the upright v2-L on the right side of the car.
As these have no markings, which is which?
sebtarta is offline
Old 01-17-2019, 06:36 PM
  #2513
I also took measurements between the 811 vs SRX8 wishbones. I do not think they would work, unless you manage to file enough on the SRX8 to match the 811
Sorry for the bad light on some of these pictures, but you can see the difference on the mounting points. Personally I do not think it is worth going through all that trouble in trying to make them fit.
sebtarta is offline
Old 01-18-2019, 12:38 AM
  #2514
Looking at the pictures its a no brainer. Not worth the effort. Thanks a lot Sebtarta for pictures and go through! Doc
Old 01-18-2019, 02:30 AM
  #2515
The flatter side goes towards the front for the 2.2 . Has nothing to do with hub location, you're just moving the camber link forward so that it doesn't touch the shock
Old 01-29-2019, 07:12 AM
  #2516
If it would stop raining during the weekend and rain during the week, I might be able to run the car!
sebtarta is offline
Old 02-04-2019, 08:12 AM
  #2517
Well I managed to drive the car on Sunday. YAY It was fun, running like a champ. Many crashes, no injuries. Any recommendations on clutch springs for clay low grip?
Does anyone have any 13T (non)vented clutches to off load? If so let me know, thank you
sebtarta is offline
