Serpent 811 Cobra Buggy 2.1
#1756
The box setup with rr 2.3 sb, fr 2.5sb give good rear traction, as mention, i not pro. Try shock 0 rebound with red rr spring or maybe fr shock blue ring, upright spacer all behind is good. This buggy is too stable i think. I even run option rr/fr bracket with minimum 2.5 squat. 14degree c hub good to tame it agresiveness. Anyway try matrix super soft tire (fast ss)
#1758
Guess have to buy selarately
#1759
I haven't tried these yet but intend to. The truck rear uprights are taller so this moves the roll center up if you don't make any changes to the link position on the tower. This will decrease roll in the rear and should reduce rear traction some. This is a good thing because the car is so locked in the rear. I think it changes the bone angle a little also so that might have some effects.
#1761
Running 18k-18k-10k, feel like so much power but streering is less, guess 15k-15k-7k will be better. Any opinion?
#1763
#1766
hello everyone! im looking to upgrade the servo saver setup to aluminum. any ideas which steering rack bar option works best? any help is greatly appreciated.
#1767
serpent v3 rear/center coupler set part#ser600504
hope this helps.
#1769
#1770
Insert 6 is max toe in (-3) if not mistaken, wheelbase is adjusted with spacer on upright, wheelbase do effect turning radius critically. Dont understand with overhaul wheelbase.
