Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-21-2008, 10:56 AM
  #11476
bmmer701's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Hi-LowBlow
The Pro-Spec Diff comes with the POM(Delrin) out drives. The aluminum out drives will be the option parts for the Pro-Spec Diff.
I have been using both the aluminum and the POM out drives and both work excellent.
would you recommend using the pro spec diff with pom (delrin) outdrives in mod? or should we get the aluminum if we're running mod
thanks
bmmer701 is offline
Old 03-21-2008, 11:40 AM
  #11477
thanks
Performance wise, I personally don't think there is huge difference between the aluminum and the POM outdrives. But it seems like the diff last longer with using the POM outdrive.
I have been using both for Mod and 10.5 and have had no problem at all.
You will be impressed how smooth the Pro-Spec Diff works.
Hi-LowBlow is offline
Old 03-21-2008, 11:51 AM
  #11478
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Is it smoother then the normal diff?
Is it worth the money, or?
BlackedOutREVO is offline
Old 03-21-2008, 11:53 AM
  #11479
Stew Noble's Avatar
Much smoother, it will also stay smoother for longer
Stew Noble is offline
Old 03-21-2008, 11:54 AM
  #11480
Any pics of it in your car?
Is it more sealed then the last one?
Old 03-21-2008, 12:13 PM
  #11481
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hiro,
when is the new car going to be in the "system"
- Chris
Hebiki is offline
Old 03-21-2008, 12:34 PM
  #11482
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by B18C Turbo
uses same thrust washer! nice! 8 piece thrust ball!! what size thrust ball!
Sorry use new diff thrust washer 2.8x5.8 x1
RC MARKET is offline
Old 03-21-2008, 12:36 PM
  #11483
RC MARKET's Avatar
HPI
today was updated web site New Cyclone TC,
but not have titanium pin & turnbuckle & New shock .
http://www.hpiracing.co.jp/contents/..._tc/index.html
Old 03-21-2008, 01:29 PM
  #11484
BlackedOutREVO,
yeah, it's definitely worth it.
For the Pro-Spec Diff, you don't have to tighten so the diff will be able to work way smoother.
1. Large Ceramic Differential Balls (3mm)
2. Bigger diameter for the holes on the pulley. (less pressure)
3. Bigger Differential Screw (2.6mm) with more thrust balls
Thanks,
Old 03-21-2008, 01:33 PM
  #11485
Originally Posted by Hebiki
Hiro,
- Chris
What's up Chris!!
I will give you the update for the new car every week! so that you won't miss anything, does it sound good for you? haha!!
see you tomorrow anyway...
Old 03-21-2008, 01:42 PM
  #11486
BlackedOutREVO,
Thanks,
As it is, I dont think I want my diff any looser, you can free spin mine, and the diff doesnt slip one bit
But I get what your saying, sounds nice! I will buy the diff kit when my current outdrives are no good anymore
Old 03-21-2008, 01:44 PM
  #11487
Hebiki's Avatar
What's up Chris!!
Hiro, hell yah that'd be awesome. im trying to run your car, but when i was about to purchase the MooreSpeed.. i saw the announcement for the new car. so i'll just wait until the new one comes out.
- chris
Hebiki is offline
Old 03-21-2008, 02:40 PM
  #11488
Trader Rating: 32 (100%+)
So is this version of the Cyclone a replacement of the AME car?Is it the new High end spec sedan for HB?I have a brand new AME that I can just update or are there huge changes other then the diff?
Hebiki,it's cool to see you branch out to a different brand besides the Big T.The cyclone from the original black version have been super fast and is still fast and I like the idea of upgrading rather then replacing.Hopefully we get a Hotbodies series race up here sometime.
racenut123 is offline
Old 03-21-2008, 03:18 PM
  #11489
This is like the black cyclone, its just a cyclone
Hara, Moore will have there version soon im sure So no, it isnt replacing the AME
Theres nothing major that you cant upgrade, but I dont think the car will be any faster then the current cyclone
Old 03-21-2008, 03:45 PM
  #11490
That makes sense.I guess I will be ordering the new diff then.You running Reedy this year?You should.
