Crankshaft rust >
Crankshaft rust
Crankshaft rust
Old 08-06-2013, 03:31 AM
Trader Rating: 13 (100%+)
Default Crankshaft rust
The motor has a little over a gallon and this is what the crank looks like.
20% Maxys
JOE SI is offline
Old 08-06-2013, 03:33 AM
Default Crankshaft
.12 RBM3
JOE SI is offline
Old 08-06-2013, 03:45 AM
Aza088's Avatar
Do you have a photo?
What fuel do you run?
How do you maintain your engine after you run/race?
Aza088 is offline
Old 08-06-2013, 04:23 AM
godzukihop's Avatar
Trader Rating: 32 (100%+)
20% Maxys
I don't care what fuel brands say, you have to use after-run oil. I fell for that once and it cost me a set of engine bearings.
godzukihop is offline
Old 08-06-2013, 06:32 AM
TeamCarnage's Avatar
Trader Rating: 31 (100%+)
+++1. I fell for the same line of BS. I always run all the fuel completely out. For a very short time, I didn't use ARO. I figured I was racing at least once a week and rust wouldn't form in less than a week in a controlled environment. That cost me a good engine. Rust can form overnight. If I'm at a 2 day weekend race, I still use ARO, for peace of mind if nothing else. I also take my engines apart every other race day to check for wear and staining, either carbon deposits or any spots of rust. Engines are to expensive to ignore.
TeamCarnage is offline
Old 08-06-2013, 09:39 AM
I'm getting back into the hobby after 5+ years so I'm not sure what the best brands are now. Can you recommend a good ARO? Thanks.
Mavs is offline
Old 08-06-2013, 05:49 PM
Someone told me they're carbon deposits from blow back, not rust
JOE SI is offline
Old 08-06-2013, 06:02 PM
Default Rusty crank
It's had it since 2 weekends ago but opened it this past Sunday again to see and it had 5x more rust or whatever that is
JOE SI is offline
Old 08-06-2013, 07:24 PM
godzukihop's Avatar
I buy my ARO from Murnan Modifieds.
Old 08-06-2013, 07:37 PM
Phil Trotta's Avatar
Marvel mystery oil. Perfect after run oil Using it for years .. Or transmission fluid ....
Phil Trotta is offline
Old 08-06-2013, 08:05 PM
Gary NJ's Avatar
GMK Supply "Afterlife" ARO. Marvel Mystery has been known to cause problems with silicone crank inserts.
Gary NJ is offline
Old 08-06-2013, 09:11 PM
Cool
Gary. Never once in any of my engines ...
Old 08-06-2013, 09:30 PM
Bundy_Bear's Avatar
Trader Rating: 11 (100%+)
How would one clean up that rust on the crank?
Bundy_Bear is offline
Old 08-06-2013, 11:01 PM
Take out the crack. Push a small piece of fuel tube over the crank pin to protect and then with a Scotch Brite pad you can wipe it away.
Roelof is offline
Old 08-07-2013, 04:30 AM
I've been using Mugen after run oil.
But haven't done it on this motor yet and it shows. Just hope it comes right off and doesn't affect performance, its the fastest motor I own with plenty of power
JOE SI is offline
