"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors
#573
http://www.youtube.com/watch?v=i0ZcKpL2-Yc
#574
Jilles, what set-up you used on your esc during the last TITC race?
Maybe if you don't mind in your future races, your car set-up sheet to include your esc set-up as well. Thanks.
#576
Mugen10,
For carpet rubber tyre the car is excellent. I quess at your hometrack most guys run foam tyres? As foam is not very populair worldwide, Tamiya made the 416 for rubber tyre racing, the car performance not so bad with foams, it only needs little stiffer chassis.
IQ0,
At that time I ran 5 cell 3.5, gearing about 8.6
Power program 4 on the nosram with 1 autobrake and 1 initial brake.
This was still the old version speedo, on the new I should go for 5 or 6 and autobrake 2.
Jilles
IQ0,
Jilles
#578
#579
Hi Gilles,
In the video a see you use the steel wheel axle. Do you ever use the titanium or aluminium versions? And why? Thanks.
#580
Jilles, do set your steering travel to full lock? And do you use expo on throttle or steering?
#581
Was that when you were using Nosram Matrix (1,4,1,1)? And when you use Nosram Pearl its equivalent to 1,5/6,2,2 as you mentioned? What sort of motor temp did you target?
#582
Hi Jilles, good to know that you are much easier to access through the forum and thank you for your patience with us. Only got a few questions all about in-board and out-board toe and a little about the shocks.
1) What effect would you get if you use in-board toe vs out-board toe on the front of the car?
2) Again same as above in regards to out board toe and in-board toe for the rear. If I am running 3deg rear in-board toe Vs I use a 1 deg out-board toe with 1 deg alloy rear upright and reduce the inboard toe to 2 deg, would the car feel any different?
3) Full rebound shock Vs No rebound shock, which to use on which kind of track.
Thanks in advance.
Thanks in advance.
#583
Hello Jilles
A question regarding rubber tires on asphalt:
Do you always sand / roughen your tires before using them on asphalt?
With a truer such like the one from much more?
If yes, which grain size of sanding paper? 400? 600?
Or do you use only braking cleaner before applying the traction compound?
And what about carpet?
Thanks...
Thanks...
#584
Hello Jilles
Thanks...
Thanks...
#585
Mark,
Thanks for your comments.
Try thinner oil to get more reaction in chicanes, harder springs also helps.
Disadvantage is overheat tyre faster.
Barry,
We always use steel wheel axles, I think for the 415 there were Aluminium available but haven't seen them for the 416.
Dameetz,
Normally I use 95% steering travel. I use 0% expo on throttle but most of the time -20/-30% on the steering.
Speedo is true, 1,4,1,1 is same as 1,5/6,2,2. In modified you don't have to worry about motor temps, even in Bangkok you will not go above 80 degree.
Mike,
1) I have tested a lot with inboard toe-out in front and it gives more steering in middle and exit corner, but to little respons going into corner.
So I not run much inboard toe-in, I always use 1 degree toe-out on the front wheels to get better stability on the straight line.
2) I haven't played with this a lot, on the 416 I always use inboard toe-in, always use 0 degree hub. The only differents it makes, using 1 degree rear hub is that you will not change the wheelbase too much. I can't really give you an answer what is better.
3) 90% of the tracks I use zero-rebound, only some carpet races with rubber tyre I use little rebound.
Nutsisneat,
Don't bother use any sand paper for rubbing tyres, most of the time I will not use it. My experience on carpet tracks is that new tyres are good from the beginning and you can use the tyres with same performance for a long time.
Jilles
Barry,
Dameetz,
Mike,
Nutsisneat,
Jilles
