MOTONICA P81RS >
MOTONICA P81RS
MOTONICA P81RS
Old 02-11-2012, 06:55 PM
  #286
garen's Avatar
Contact me to order for the time being. First batch sold out, more coming in about 2 weeks, maybe less.
garen is offline
Old 02-11-2012, 08:50 PM
  #287
SOLOARTIST 702's Avatar
Originally Posted by garen
00124
whats up garen
SOLOARTIST 702 is offline
Old 02-11-2012, 09:45 PM
  #288
RahjahDat's Avatar
Trader Rating: 101 (98%+)
Default wow
hawtDawgie i want me one of these!!! thanks for the info guys
RahjahDat is offline
Old 02-12-2012, 06:35 AM
  #289
garen's Avatar
Hey Will, same old, when are we going to see you at the track again?
garen is offline
Old 02-12-2012, 09:42 AM
  #290
after winternats ill be down
Old 02-15-2012, 07:17 PM
  #291
garen's Avatar
I got to try my car with the RS2 updates on it, minus the rear upper camber link, this past weekend. I first assembled the new parts to be as close to the old parts were with the exception of the shock geometry and the king pin angle. With the supplied shims, you can go from what Motonica calls the +1.2 angle to 0 angle. With 3 more shims on either upright, you can go to -1.2, which is where we were with the old uprights flipped left to right.
So I ran the 0 angle, the front shocks mounted in the outer position on the arm, lowest hole on the tower, and the ackerman in the middle setting both laterally and longitudinally, with about 3mm spacers below the steering ball stud (all just about where they were on the old uprights). I ran the car and took some lap times. Just for kicks, I put the RS shock tower back on, readjusted the ride height and took some lap times again. The lap times were virtually identical. I put the RS2 tower back on and tried the ackerman in the most aggressive setting- arm out and steering link all the way back on the arm. Took some lap times again, and again, they were virtually identical, maybe 1/10th faster on my fastest lap. Feel-wise, the front end felt like it gripped better as it entered and went into the corners. Overall, the car felt very similar to the RS, but as soon as I get more of the shims, I am going to try the -1.2 angle, as I think this combined with the ackmerman and shock angles should yield in slightly faster lap times.
As for the club race, I TQ'ed and won, so the first US win for the RS2 is done.
garen is offline
Old 02-27-2012, 03:43 AM
  #292
stefan's Avatar
Balestri back on the Team
I was wondering how he'd get along with Collari at Capricorn.....
stefan is offline
Old 02-27-2012, 08:56 AM
  #293
romain_f's Avatar
Great news!
romain_f is offline
Old 03-20-2012, 12:31 AM
  #294
garen's Avatar
RS2 assembly/setup guide available for download here http://www.motonica-usa.com/support.html or just click here http://www.motonica-usa.com/Support/...up%20Guide.pdf
garen is offline
Old 03-20-2012, 01:31 AM
  #295
stefan's Avatar
Awesome work Garen, thanks a lot for that!
stefan is offline
Old 03-20-2012, 02:13 PM
  #296
Default Thanks!!!
Excellent guide Garen,thank you very much
dsond is offline
Old 03-21-2012, 10:08 AM
  #297
garen's Avatar
You guys are welcome. Hope it helps you get the most out of your cars.
garen is offline
Old 03-24-2012, 11:49 PM
  #298
josecarlo1129's Avatar
Thanks Garen! This is what I have been waiting for. Cool guide! Cheers.
josecarlo1129 is offline
Old 03-27-2012, 11:30 AM
  #299
garen's Avatar
We had our Motonica GP this past weekend. Chris Verano qualified 7th in the A Final expert. I did poorly in 1/8th, qualifying 13th. Ralph Ayala qualified 1st in the sporstman, with his VMR tires equipped RS2. I also ran 200mm sedan using the VOX .12 motor in a borrowed Kyosho V1RRR, and I qualified 3rd.
The A and B finals got rained out so Chris took 7th in the expert class and Ralph took the sportsman win, only the second time racing his RS2.
garen is offline
Old 04-22-2012, 01:22 AM
  #300
asw7576's Avatar
Hello guys, can someone with motonica cars measure the total length and thickness of motonica pivot balls ? In millimeter.
Thanks a lot......
I want to compare it with mugen seiki pivot balls, i want wider track width.
asw7576 is offline
