Tamiya Ta06
#1696
Green slime is a huge help absolutely I think everyone should have it in there tool case. And yes I bent up the front turnbuckles really bad and went titanium on all the steering and adjusting ones. I'm debating though on getting the carbon chassis by VBR racing or possibly the exotek one. It's just the battery load is highly inconvenient you either use the batteries with the deans connections that come from the corners or you have to use the posts and make sure the terminals are far enough apart to fit it once the battery is loaded.
The only 2 issues I have with the Exotek conversion is 1: the upperdeck is not level with the lower deck. it opens towards the front. and 2: the steering was binding. I remedied this by placing a .5mm tamiya aluminum shim under the 2 screws that hole the upper steering post support. now its smoother than factory and there is no play.
#1697
C-Hub question
Hi Guys..
I have bought ta 06 pro and running fot tcs on sunday, i love the car..but i crash during turn and broke my c-hub...
my question is, will it be posibble to use 417 part? to replace part c, e and f?
since 417 is carbon where ta 06 is plastic....
thanks
thanks
#1698
If you want the carbon reinforced c-hub, you need part #54031
These are normal plastic:
part #51293
To the best of my knowledge, they fit the TB03, TA05, TA06, 416/417.
#1701
i have yet to break them on my ta06, but if i do, i will probably get some aftermarket aluminium ones like this
http://broadtechonlineshop.com/eagle...l.aspx?id=3468
#1702
Trader Rating: 89 (100%+)
Shorty Lipo
Hey,
Has anyone tried the shorty lipo in this car with what results and can you tell me what works best,placing the lipo towards the front of the car or the rear???
Thanks!
Thanks!
#1703
It has been my experience that the carbon-reinforced c-hub is more likely to break than the normal plastic one. It may be more rigid for more precise function but will break on a hard hit where the normal plastic just flexes and survives. Since I am still sharpening my driving skills, I hit things all too often, so I use the normal plastic c-hub
part #51293
part #51293
Another question is...is it better of using ta 06 wide or 417 wide....since I'm goin to use ta06 for tc, but the body will be 190mm, so if I use ta06 then the wheel will be inside...
The reason I asking is I have know idea what is the diferent in tracke width with handle of the car? Is it easier to drive with wider tracke wide or shorter...
Thanks in advance...and sorry for my english..hope everyone understand..
Cheers
#1705
I use a full size hard case in an eagle racing conversion, and it seems fine
#1706
Thanks Sam! it is just something I am thinking about trying to play with the balance of the car before I play with weights!
#1707
this is when I HAD the EacleRacing Chassis. I now have the Exotek.
See, i USED to use them for drift. +12mm offset wheels rear and 10mm fronts...
this is MY baby...
#1709
Do not get those. 3Racing and Yeah racing make some. the tops can use bearings or bushings and one good tap, the bearing is seized. besides, those are for drifting. 8* ackerman and 8* camber. i run 3 racing arms from a 417 and hubs for a TB03D
this is MY baby...
this is MY baby...
#1710
what servo, motor and speed control are most of you running with it? also what radio? does any of that even come with the kit because it doesnt look like it? Im going to order everything soon.
