Like Tree248Likes
Xray XB4 thread
Old 02-27-2015, 11:44 AM
  #7306
Trader Rating: 15 (100%+)
Originally Posted by littleZEN
So after only 3 days of running my car I've noticed that the driveshaft pins show considerable wear. I've read that they do wear fast but I didn't expect it to be this fast. How often are you guys replacing the pins? Or rather, at what point should I replace the pins? I understand its cheaper to replace pins than outdrives but only after 3 days of running seems excessive to me. Are there any ways to prolong the life of the pins?
Whoa, that's not right. My '13 I have ran 25-30 races, and I only replaced my pins this winter. The centre cvd's were the worst, but still usable. 3 race days though?
HeavyD99 is offline
Old 02-27-2015, 11:48 AM
  #7307
jmackani's Avatar
Trader Rating: 14 (100%+)
Did you put any grease on them?
jmackani is offline
Old 02-27-2015, 11:58 AM
  #7308
Trader Rating: 30 (100%+)
I'll try to take a picture and post.
I don't grease the pins and outdrives. Only the cvd portion. Instructions don't state to grease them either. Am I suppose to? I'd imagine it would just fling off and/or attract dirt.
littleZEN is offline
Old 02-27-2015, 12:08 PM
  #7309
skeasor's Avatar
Originally Posted by big chris
The zero offset 12mm hexes are not for B5/KYO offset rims, the axle barely has enough threads. They will work with 22 style perfectly though. The +1.5 is real close to stock and the +2.25 is a touch wider with B5/KYO style rims.
GSHobby has 1 or 2 center diffs in stock for the guys looking. Call 479-648-1994 I don't think they are on their website.
Exactly what I was looking for. Thanks!
skeasor is offline
Old 02-27-2015, 12:28 PM
  #7310
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Sounds like you need to turn your current limiter and brakes down to me
BDRMBULLY is offline
Old 02-27-2015, 04:05 PM
  #7311
rcgod's Avatar
Trader Rating: 33 (100%+)
The instructions say to grease the pins and outdrives. I use a lube called white lightning made for bicycle chains. It's actually not dry but waxy and doesn't attract dirt or fling off.
rcgod is offline
Old 02-27-2015, 06:04 PM
  #7312
jmackani's Avatar
+1 if he does use grease it does not take much.
jmackani is offline
Old 02-27-2015, 07:13 PM
  #7313
skeasor's Avatar
Thanks! I must've missed this step in my build too.
skeasor is offline
Old 02-28-2015, 12:14 AM
  #7314
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
NO.. The outdrives and pins suck.. turn down your brakes is a lame response for poor outdrives.
Look at a D413 to compare.. They show NO signs of use, after 5x the drive time. ..
MaricopaAgent is offline
Old 02-28-2015, 01:02 AM
  #7315
Little grease always helps. I've had mine since launch(UK) and I'm still on all original drivetrain. The pins are marked on mine but perfectly useable. I will change them soon. It's been used 1/2 times a week and it's been driven hard. I don't hit things too much but it's really been hammered. Look after things and service the car regularly and its gonna last for ages.
sime46 is offline
Old 02-28-2015, 07:37 AM
  #7316
All I have to say it look at a HB outdrives.. They Win..
We have a better car overall. They have much better outdrives. NO COMPARISON.
Old 02-28-2015, 07:38 AM
  #7317
Anyone call rcamerica to see when they will shipping the free replacement?
Rico54 is offline
Old 02-28-2015, 08:29 AM
  #7318
crazy nick's Avatar
Trader Rating: 27 (100%+)
So as for switching hexes from 14mm to 12mm, I was going to order from amain the xrays , however they are on backorder. So I went to my local hobbyshop and bought a ton of different size plastic ones( not running just for fittment). So I came up with proline pro2 rear aluminum clamping hexes for the rear and scte hexes for the front. This give me stock xray width with 12mm associated wheels.
http://www.prolineracing.com/perform...-clamping-hex/
http://www.losi.com/Products/Feature...rodID=LOSB3493
crazy nick is offline
Old 02-28-2015, 09:18 AM
  #7319
rcgod's Avatar
Nice find!
rcgod is offline
Old 02-28-2015, 09:42 AM
  #7320
BDRMBULLY's Avatar
I used these on my scte . Same width and much cheaper...
http://m.ebay.ca/itm/351326422748?nav=SEARC
