Kyosho v-one rrr
#1186
Re: ..
Originally posted by junito yukiyu
i,ve been trying to put the stupid diff on mine and the akerman is giving me hell , I NEED HELP!! , if any body knows a trick or something , plesa share it!!
junito yukiyu
junito yukiyu
All you need to do to make the diff housing fit without hitting the 11 akerman is use the 4.8 mm ball ends, the same as the steering knuckle ends, and use the 4.8 mm ball cups. If you do this you shouldnt need to file anything, you may even have enough clearance to use the 12 if neccesary.
#1187
Re: ..
junito yukiyu
junito yukiyu
only a few shims from your local hardware store.
#1188
Re: ..
junito yukiyu
junito yukiyu
#1189
Hey guys,
I am wanting to buy a VoneRRR, where is the best place to get one from?
#1190
Originally posted by TRAJ
hehehe i had a RBv12 inline pipe set part number #01751-402K http://www.rbproducts.com/mainEn.php...oudes_inline12
and still wasnt get the speed i wanted
#1191
I'm currently running a 25T 2nd on a 45m straight (cant find a 24T), still got 26/27/28T gears to play with.
#1192
#1193
Originally posted by InitialD
What tire diameters you're playing with Nimo?
#1194
Use longer screws and add shims as spacers to lower the ball ends to the point that the ball cups will not hit the diff. That is how I did it. Probbly can use the 12 Ack also now. Hope I helped. No need to buy extra parts or sand down parts.
thanks.. does anybody have pic's of it??
the problem i have is.. that i'm the only one that i know off that have that car in Puerto Rico as of right now!! , i know it sounds funny but.. a lot of people that i know got it on order.. thax angain!! pics??!!
#1195
That's it Nimo, gear down to go faster.
#1196
Nah i havnt run the RRR at Moorebank yet but i am very excited to
In the meantime I`ll have to make some sort of decision on what pipe to get....interesting to see the comments made here about pipes. Thats the one thing about Moorebank.....as much as you need top-end its also nice to have some serious bottom-end for the slower parts of the track
Cheers
#1197
no need for pics.!! it's done!! ,thanxs!!
yukiyuuuu!!!
yukiyuuuu!!!
#1198
Originally posted by AndyT ©
I`m looking forward to racing the RRR at Moorebank, but at this stage looks like it`ll be the 20th March meeting when it makes its debut there (shift work )
Cheers
Cheers
#1199
Has anyone used the Skyline Racing 4mm Rear Shock tower?
Is it actually stronger than the stock one?
Is the KAWAHARA Rear Shock tower better than both?
#1200
Yes its much much stroger then the stock shock tower
I think it is just as good as the Kawahara one only cheaper
