Team Losi JRXS Type-R >
Like Tree52Likes
Old 06-03-2007, 06:09 PM
  #4306
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
anybody looking for a second Type R with Tons of spare parts NIP and springs check it out
http://www.rctech.net/forum/showthread.php?t=166364
Marcos.J is offline
Old 06-03-2007, 06:25 PM
  #4307
hobbipro's Avatar
Trader Rating: 23 (100%+)
What are you using for the aluminum hex wheels adapters? I see losi offers 3 different thickness ones for the JRSX, but is the axle diameter the same on the type R?
hobbipro is offline
Old 06-03-2007, 06:27 PM
  #4308
Super Moderator
Marcos.J's Avatar
these LOSA9686 Alum .165"w (STK) Wheel Hexes
Marcos.J is offline
Old 06-03-2007, 06:43 PM
  #4309
hobbipro's Avatar
Thanks, appears everyone is out of the standard hex's.
hobbipro is offline
Old 06-03-2007, 06:44 PM
  #4310
Super Moderator
Marcos.J's Avatar
i got some it comes with the car
Marcos.J is offline
Old 06-03-2007, 06:51 PM
  #4311
hobbipro's Avatar
Sorry, I ment to say metric ones that are aluminum that can be used with premount tires such as takeoff's. Tried all the major losi parts places, speedtech, stormer, losi parts, ebay...noone has the 9686.
hobbipro is offline
Old 06-03-2007, 07:00 PM
  #4312
Super Moderator
Marcos.J's Avatar
i bought the last 4 sets that stomer had a few weeks ago
Marcos.J is offline
Old 06-03-2007, 07:08 PM
  #4313
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
What did you guys notice when you removed the "JR" link and went to a standard ballstud on the caster block?
HVFracingwilly is offline
Old 06-03-2007, 07:16 PM
  #4314
POOKYT's Avatar
I am 98% sure the Hobby Town in Memphis has either 1 or 2 pairs of them on the shelf. If your in a bind give them a call.
Brant
POOKYT is offline
Old 06-03-2007, 07:27 PM
  #4315
Super Moderator
Marcos.J's Avatar
less steering
Marcos.J is offline
Old 06-03-2007, 07:42 PM
  #4316
hobbipro's Avatar
Thanks guys, just went with the 9687's. there only .030 thicker. They will be fine for club racing. I hate taking off the wheel and digging the hex out, and the pin rolling off the table...you get the idea. I thought the Type R was shy of 190mm anyway.
hobbipro is offline
Old 06-03-2007, 07:58 PM
  #4317
POOKYT's Avatar
Originally Posted by Marcos.J
less steering
Ditto!!! The JR. link should keep the front end flatter than the standard link. You really need to try it both ways because so many like one over the other and it normally comes down to your prefference.
Brant
POOKYT is offline
Old 06-03-2007, 08:00 PM
  #4318
Super Moderator
Marcos.J's Avatar
Brant
i love it i ll never go back to the ball stud!! just have to install a turnbuckle in the jr link to have easier adjustment for camber
Marcos.J is offline
Old 06-03-2007, 08:33 PM
  #4319
POOKYT's Avatar
I ran Todd's '06 nats set-up today and it was Wonderfull!!! The only changes I made was to go to 6 deg. front blocks for more high speed steering around our sweeper and to 12.5 rear springs. We made a goof and our track was sprayed with a mixture of old nitro fuel and VHT. The track was a slick mess for the first two rounds of quali. but was really good for the mains. Last year we were cutting the VHT with Methanol and it was very sticky. Ya live and ya learn I guess. LOL We race on a med to high bite out door parking lot and I had always loved the 6 deg. blocks in the old car and after today I will be running them for the most part in my Type-R. Pick up a set and give them a shot for yourself. One more thing........I don't know how I got away with it but I didn't break a single arm all day! Now my other buddies broke several of the original kit arms but after Ryan put on his new set he actually went out and broke a C hub in the third qualifier. So the answer is that the kits arms are weak but the newest replacements are much much better. Once we all get the new ones this will be a dead issue.
Brant
POOKYT is offline
Old 06-03-2007, 08:36 PM
  #4320
POOKYT's Avatar
I love it as well!!! On my Jr. link I threaded the hex end from the outside in towards the ball end. This way if I need to adjust all I have to do is unscrew the top screw out of the C hub and I can use my .050 wrench to screw the set screw in or out. So far the best part is that after I set it to -1 deg. it has not moved even after several collisions.
Brant
POOKYT is offline
