Xray t4'15
#1126
At Al's, its probably track debris causing it. If not, you may have the mesh a little too loose. With 64 pitch, it has to be perfect gear mesh, especially now with the stronger motors. I suggest going to 48 pitch if it continues once the mesh is set perfectly.
#1127
Make sure the screws are as long as you can possibly use without them fouling on the motor internals. Then tighten the screws down really tight.
And as suggested, use 48dp. This will allow a small amount of movement in a big crash without stripping the gears.
#1128
Clean the motor and motor mount with brake cleaner to make sure there's no grease/oil on the surfaces.
#1129
Are you using some spring washers on those motor screws?
#1132
Are you sure the edge of your motor does not rub on the upper deck so it can not be tightened fully. Some motors either do not have a beveled edge or one of the motor screws in front rubs on the top deck, which can be solved by rotating the motor some degrees to the next mounting holes.
This issue is also described in the manual.
You are not using too long screws to secure the motor, in the motor mount, so they tighten against motor internals instead of the motor mount?
#1133
Is there any difference between a regular panaracer spur and a yokomo branded panaracer spur?
For instance, will the following work for the xray?
http://www.amain.com/rc-cars/yokomo-...7-6496/p242268
#1135
Has anyone got a good carpet ars setup
#1136
Build your ARS on your car and set-up as close to your normal set-up.
Than you can play with your ARS rod to set it higher or lower.
The rest is your feeling and ability to handle your car.
For my self I have build the car and have only driven with ARS and it is good.
Good Luck.
Ed
Good Luck.
Ed
#1137
Well, I found my problem. I thought I would post so maybe someone else doesn't make the same mistake. The stripping problem was caused by the button head screw that goes on the bottom of the chassis into the motor mount. It came loose and was allowing flex in the mount which was allowing the play between the spur and pinion.
#1139
Good Luck.
Ed
Good Luck.
Ed
The problem I found was the car always felt tail happy and I wasn't confident in really pushing with it on.
The best set up was adding 4mm shims to the inside chassis mount and mounting the outside ball stud on top of the arm rather than below. Set static rear toe to 1 degree in. With this the rear was more planted and I felt more confident with the car. With this set up I could get a quicker single lap time, but the car was still inconsistent, a problem I found using the ARS.
I have changed back to the standard rear set up (non ARS) and found I have a lot more confidence in the car and lap times are more consistent and therefore the overall race run is quicker, even if the single best lap is fractionally slower
#1140
They're an extra layer of backup safety. Personally never had a motor come loose, but then again, always used spring washers. Nothing more annoying than a DNF because of lost mesh. And I have to say, my car has done some spectacular aerobatics (sic) at times.
