Hpi Pro 4
Hello all,I would like to ask if you guys you have an extra PRO4 shock tower(front)and I will buy it just PM me.Thanks
Pro4 Hop-ups
I Bought a lot of Hop-ups for my Pro4 to make it perform better and look good.
Good to Say it looks like a Pro4 now than what I did to it before.
I made my own specs and modifications... and so far it worked for me in most Races. though with the new replacements and Hop-ups I got... I think the Handling of the Car made it tougher for me to make the Car Run Straight.
I Got a NEW Hara Upper Deck, Lower Deck, Gear Bulk, Alu Camber Link, Delrin Rear Diff., Spool, Dogbones, Carbon Shafts, Alu Shock Stay, Titanium Screws, and a lot of Minor Ho-ups....
GeeeeeeZ! it felt like I was Driving someone else's Car... I could not feel the Grip and Ride... I need to adjust my Driving again and adjustments with the Car.
I suggest that you go easy with the hop-ups you will make with your Car...sort of place it one at a time and see the Handling changes so it would be easier...
Now I have to learn to adjust to the New Sooped-up Pro4 I made....
So Far Spool is working great for me...
wouldn't it been cheeper to just buy the Hara Edition Pro4?
Originally Posted by rc-zombies
now that Tamiya is set to release the new Evo-V
and Yok has the SD-LCG . both cars having low CG and aluminum bulkheads
Wonder if HPI is working on working a similar concept..presumably the Pro5?
Originally Posted by Nicadrauspro4
Yup, HPI is on its way designing their new shaft driven tourer. The Pro5! Sources say that it's still uses the C-Hubs, knuckle arms, suspension arms and some other Pro4 & Cyclone parts.
I need some help guys. Are TC3 dogbones a direct fit for the Pro4? INcluding the steel pin that goes in the outdrive? I used to own a Pro4-but I cannot remember.
Ray..
yes a direct fit.. I used the TC4 HD bones on mine...
HPI PRO 5
Have I read correctly!? Is HPI really working on the PRO 5, or is this a joke? Can I please see some evidence of this? Maybe there is an article about this, or is this inside info from HPI drivers or something? What's the source? Thanks!!!
Pro 4 Interchangeble parts
Does anyone know of anyother parts we can use on the pro 4 from other manyfacturers like Associated, Tamiya, Yokomo, etc. Maybe their shaft car parts can also work on the pro 4, since sometimes Tamiya and Yokomo have interchangable parts...Has anyone found diffs from other kits that fit the pro 4 or anything else? Thanks....
Oh man that's cruel... really a pro5?
Or are you pulling something here? LoL!.. then agian, i'm not sure that i'm all that excited. There's not that much that can change to the basic design right.
Got any solid specs?
The T2 steering knuckles fit with a .025" shim.
There are no definite specs yet but I'm sure it will be showed as they progress with the design. As said earlier, the C-Hubs, knuckles, rear hubs, suspension arms, and other parts of the Pro4 and Cyclone will still be used on the Pro5. The Pro5 will be the new competitor of the new Tamiya Evo 5 and Yoke SD.
Just to clarify, Pro4 parts are still manufactured and available at almost any cities in the world. HPI would not stop its production yet because of its demands from the consumers.
