Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012
#466
Also had issues with the 2 speed shaft and the bearings going over it, it was like the shaft thickness tolerance was slightly off.
#467
Hey guys, thought id just touch base and say gday to all,
I have a fresh 747 i built up a couple of weeks ago, just playing around with final small touches, aligning spur/pinion 100% and getting my SRS-N body painted etc..
Mine went together really nicely, no issues at all with the build from bag 1 til the last bag, my braking feels really good in every aspect..the real test will be on the track though I guess as always..
Also, If anyone has a spare front oneway kit they want to sell, I'll snap it up straight away..Til next time..
Ryan
Ryan
#468
Just got my new brake pads and both have gray material on them so I will wait and see how it goes on Sunday with them in.
Is it possible that there is 2 different compounds?
#469
Update
Brake issue fixed, Tyre wear has been lowered now I am just trying to get rid of some understeer once that's done I will be happy.
#473
New 747 options??
Low shocktower to be able to mount the RCM Super-Short shocks # 160124 and this lower center of gravity. Continue to use your current springs, so special short ones needed.
http://www.serpent.com/product/804306
and
http://www.serpent.com/product/804305
and
#474
Hi guys, so I noticed that the engine rides too low so the aluminum plate that holds the clutch shoe rubs against the chassis when clutch is engaged... It doesn't rub when there are no shims behind the cone but if you put enough shims to find 100% contact with the spurs there is rubbing. With the stock engine mount the only options are either to not have 100% contact with the spurs (which reduces the lifespan of the pinions and spurs) or to dremel a groove in the chassis to make enough clearance...
#475
Pass you soon...
#477
I put the spurs on the clutchbell but don`t fasten it to the bell, i release the 2e spur a litlle and thighten it with the first spur. This way you can play with how far the spur are on the bell without lengthening the complete clutch. I do this to release the spurs on the bell with just the two spur tools. They won`t get too thight on the bell this way. Maybe this is a thing/idea wich can help. Could just be what you need to not have the clutchbell rub against the chassis.
#478
Maybe what i do with my xray can be a help?
Thanks though ;-)
#480
I didn't raise the engine, I realized that the engine needs to sit flat on engine mount because the crankcase of engine has some kind of flex when warm which can cause bearing failure if not perfectly seated in engine mount. I just dremeled a groove in the chassis.
