Old 05-21-2013, 11:27 PM   #466
Bundy_Bear's Avatar
Originally Posted by Blown1940 View Post
Hi Guys
I'm having issue with lack of braking even when compared to other 747's i have quite a lot less braking. I have just looked at the pads that are fitted I have 1 yellow and 1 gray is this correct?
Thought this when I built mine that the braking action was less then I expected in the pivot of the brake post in the bulkhead and it felt like you had no brakes as a result.
Also had issues with the 2 speed shaft and the bearings going over it, it was like the shaft thickness tolerance was slightly off.
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 05-22-2013, 12:03 AM   #467
Serpent007's Avatar
Exclamation
Hey guys, thought id just touch base and say gday to all,
I have a fresh 747 i built up a couple of weeks ago, just playing around with final small touches, aligning spur/pinion 100% and getting my SRS-N body painted etc..
Mine went together really nicely, no issues at all with the build from bag 1 til the last bag, my braking feels really good in every aspect..the real test will be on the track though I guess as always..
Also, If anyone has a spare front oneway kit they want to sell, I'll snap it up straight away..Til next time..
Ryan
~Serpent 747 -2013 upgrades~ 2013 REDS Racing M3-WCup Team Tuned Engines~
~2013 REDS Hipex Mr Tuned pipe set/s~ Savox~ Spektrum~ Enneti~ SRS-N/P37~
-- BSP "Ben Sterling Products Melb" --
~~~BIG THANKS TO "WALTER HOBBY RC" 4 LOADING ME UP WITH GOODS!~~~
Serpent007 is offline   Reply With Quote
Old 05-22-2013, 06:50 PM   #468
Just got my new brake pads and both have gray material on them so I will wait and see how it goes on Sunday with them in.
Is it possible that there is 2 different compounds?
Blown1940 is offline   Reply With Quote
Old 05-27-2013, 11:55 PM   #469
Update
Brake issue fixed, Tyre wear has been lowered now I am just trying to get rid of some understeer once that's done I will be happy.
Old 05-28-2013, 02:16 AM   #470
Hi guys does anyone know at what track conditions would you use a solid axl front and rear and a one way for front?regards
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 05-28-2013, 05:33 PM   #471
carkillaii's Avatar
Default Changing Of The Guard!!!!
After years of running a K car I have decided to get a 747 what are the things I need to know about this car options & all!!!!
carkillaii is offline   Reply With Quote
Old 05-28-2013, 07:16 PM   #472
lil-bump's Avatar
Trader Rating: 83 (100%+)
Congrats on the new ride. Make sure you pick-up a bias weight for the underside of the chassis.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-03-2013, 05:27 AM   #473
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Michael_T View Post
New 747 options??
Low shocktower to be able to mount the RCM Super-Short shocks # 160124 and this lower center of gravity. Continue to use your current springs, so special short ones needed.
http://www.serpent.com/product/804306
and
http://www.serpent.com/product/804305
Any feedback on these new option parts?
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-04-2013, 12:48 AM   #474
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Hi guys, so I noticed that the engine rides too low so the aluminum plate that holds the clutch shoe rubs against the chassis when clutch is engaged... It doesn't rub when there are no shims behind the cone but if you put enough shims to find 100% contact with the spurs there is rubbing. With the stock engine mount the only options are either to not have 100% contact with the spurs (which reduces the lifespan of the pinions and spurs) or to dremel a groove in the chassis to make enough clearance...
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 06-04-2013, 07:11 AM   #475
lil-bump's Avatar
I slightly dremeled my chassis. If you run the 733 clutch(non-reversed) it will rub a ton!
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-04-2013, 12:16 PM   #476
Joe Kimble's Avatar
Pass you soon...
Ok. I ll do that but will also add .2 shims between engine and engine mount. I think that a slightly taller engine mount should solve the problem. I also noticed that there is less than .2mm clearance between the engine and chassis.
Serpent America
Sweep USA
RCShox
Old 06-04-2013, 03:06 PM   #477
djiewie's Avatar
Maybe what i do with my xray can be a help?
I put the spurs on the clutchbell but don`t fasten it to the bell, i release the 2e spur a litlle and thighten it with the first spur. This way you can play with how far the spur are on the bell without lengthening the complete clutch. I do this to release the spurs on the bell with just the two spur tools. They won`t get too thight on the bell this way. Maybe this is a thing/idea wich can help. Could just be what you need to not have the clutchbell rub against the chassis.
djiewie is offline   Reply With Quote
Old 06-04-2013, 07:56 PM   #478
Joe Kimble's Avatar
That sounds like a good idea, but on the centax WC clutch the pinions aren't in contact with each other.
Thanks though ;-)
Serpent America
Sweep USA
RCShox
Old 06-10-2013, 08:08 AM   #479
nitrobeast's Avatar
Thanks though ;-)
Hey,
Dont raise the engine, just dremel the inside of the chassis slightly.
BTW, car looked good yesterday.
Rui Goncalves
Old 06-10-2013, 11:02 AM   #480
Joe Kimble's Avatar
Originally Posted by nitrobeast View Post
Hey,
I didn't raise the engine, I realized that the engine needs to sit flat on engine mount because the crankcase of engine has some kind of flex when warm which can cause bearing failure if not perfectly seated in engine mount. I just dremeled a groove in the chassis.
Serpent America
Sweep USA
RCShox
Tags
rc-world, serpent, serpent 747, toy fair
