Xray T1FK05
#2641
What is the rolling chassis weight?
#2642
We just got a new batch of thrust bearings in and I will offer a buy 1 get 1 free up till this Sunday. Just order from www.axiommotors.com on the homepage and I will match however many you buy..
#2643
Rear Foams for Carpet
Hey,
What mods have you guys made to your car to get 28mm foams to fit on your cars without rubbing on the lower shock mount. I have had to grind on the arms (more than the instructions stated) and grind on the lower shock mount itself. Any suggestions and/or pics would be greatly appreciated.
#2644
#2645
#2646
#2647
Originally Posted by blr
Hey,
#2648
Originally Posted by kewdawg
Just use the center hole on the arms. Myself and others have found the mod puts the shock at a binding angle and the rim still rubs the ball end on the shock shaft, when you use the outer hole on the arm.
#2649
has any of you guys tryed putting ceramic diff balls in the diffs of the xray fk05 i have and the drivetrain is supersmooth
#2650
#2651
Originally Posted by acutts
If you are running anti squat then you will have less grip when accelerating and more under braking and opposite with pro??
Hope to see the Rizla up the front again soon
Scott
Scott
I am running the rear wishbone flat at the moment, rear anti squat (front higher) will give less grip under acc. and therefore more steering. It does this by effectively stiffening the rear end up as you are on the gas. Because of this less weight transfers backwards. It can also mean that the rear doesn't get overloaded - the old car used to transfer a lot of weight back and roll on to the outside rear if you were not smooth. You can there fore run softer springs getting more roll mid corner and possibly more grip. Its all a balance.
I do often run anti dive at the front. The opposite to kick up, so the front of the arm lower. This transfers less weight to the front under braking and can help stop the rear being unloaded and losing grip. It was running that with foams (the one time I ran foams on carpet) and often outside on rubber. Been trying rubber on carpet and have put the wishbone level to get a bit more entry and mid steering. With anti dive front end the front stays lower under acc. and helps reduce rearward weight transfer. I like it outdoors with mod motors as the reduced weight transfer front to rear keeps the car feelinglinear as my driving style is too aggressive and basically rubbish! But then again I can't fall off and hurt myself........
Cheers
Smarty
#2652
i cant get the reedy race set-up of jilles from the website.
i registered but still waiting for the activation.
i would really appreciate it if anyone is kind enough to post the set-up.
thanks in advance.
thanks in advance.
#2653
thanks in advance.
thanks in advance.
Its some sort of code that basically gets wacky when you try to print it. It comes out in two pages and everything gets scrunched together and cuts off things. There is no way of saving it unless you save the code, but it's so screwed up you wouldn't want it.
You basically have to write down everything onto a new sheet. And quite frankly, I'm too lazy for that.
A real pain in the ass.
They really dropped the ball on whoever came up with the format for it.
#2654
Here's Most of Jilles setup..
