Xray T1FK05
#2791
Originally Posted by promatchrcr
Cool, I figured it would be fine but felt a second or third opinion was in order just in case,LOL. As for pistons do you guys just use only Tamiya pistons or what?
#2792
Trader Rating: 50 (100%+)
Alex:
Does that fit the 2mm chassis too? I run rubber and gear Monster Stcok Pro around 7-7.1, whith stock spur I'm a little too high and low, same with C2.
Originally Posted by edseb
Alex:
Yeah, I like those spur gears. They are a little beafier and I use them in my L4 1/12th scale. Only problem is that unlike Kimbrough, there isn't a ridge to clip on a dust cover for the diff on the sides. That won't be a problem on sedans.
As far as fitting the 2mm chassis it should not be a problem it should be comparable to a 87 (48 pitch) Spur gear.
I hope this helps out with your roleout.
Best Regards
Alex
#2793
Xray racers, just wanted to let you know we are having the annual Beat the Heat Race here in Memphis July 30-31. You can find more info here- http://rctech.net/forum/showthread.p...5&page=1&pp=40The reason I wanted to hit you guys up about it is that I've been talking smack to the Losi guys since I run Xray. I think they may be coming stong...lol
Anyways, Toastie will be here to run electric as will Ron Atomic to run nitro. If you guys wanna come see how you measure up to one of the best non-factory asphalt Xray racers in the country then come on down. Toastie isn't the only fast Xray guy that will be here considering I seriously doubt there are many that can come to my house and punk me out...
Feel free to ask questions and such. It's gonna be a blast. So far there's probably double the number of racers planning to come than from the last 4 years!!
Quick rundown-
stock- rubber tire 24deg ROAR stock
19t- rubber tire 24deg tagged arm. Adj timing OK but must be set to 24*
mod- mod; bring it! rubber tire
nitro sedan sportsman- 12 or rtr 15, foam tires
nitro sedan expert- 12 only, foam tires
all classes ROAR weight and typical TC legal race bodies or something real close (ala Snowbirds rules)
cookout after quals are over Sat night. BYOB
anyone not having FUN will be DQ'd immediately!!!!
Quick rundown-
#2794
Originally Posted by HarshGuy
That will work fine ..I only did the cone washers as I wanted to drive a screw all the way through to eliminate the chance of a shock poping off do to the extreme G-Forces I generate when I hack someone out of a corner
#2795
I've stripped a screw into the right rear bulkhead and demolished the threads in the hole trying to get it out. If anyone in the US has bought an extra set to use any of the other bulkheads from the set, please PM me so I can purchase a right rear from you.
I'm paypal ready! Thanks.
#2796
Originally Posted by NorCal_Big_L
Which piston did you use 2 hole or 3 hole? And are you still using Xray shock oil? I will be out at SW with Roger and the boys next month on the 15th, hope to see you there!
#2797
just a simple question to all Fk05 experts, Will the fk05's chassis fit the T1 raycer? Or what do I need to make my battery config. sidexside instead of saddle pack? I mean what chassis do I need?
#2798
#2799
Does anybody know if there are any aftermarket spools available for the Xray05. I ran the Multidiff spool this weekend, but i am afraid of it breaking at some point. I know they used to make a spool for the older platforms does anyone know if it is still available or have one for sale. please email thanks.
#2800
#2803
i am not sure if they make on but I have 3 from the old fk and evo2 days. pm me if you are interested. I think one of mine has never been used.
#2804
#2805
