Losi XXX-S
#2026
Originally posted by MDM3
I was given (2) 1.125 turnbuckles instead of the 1.375 ones for the rear.(step 46) Anyone else had this problem? Maybe the LHS will have a replacement.
Jits
#2027
No it was not crossed out. Not good when I just posted and there are 3 of us already.Don't much care for those stock ones as well and that wrench leaves much to be desired. Hey wait something strange is going on.
#2028
Well I just got some short threaded shocks and one of them is missing the inside cap to hold the cartridge (o-rings, spacer etc.) pieces together. Hmmmm strike 2 for Losi. Not a good first impression for me.
BTW MDM3 I think the club you belong to is BMWCCA, correct?
#2029
Losi Quality Control
Looks like a lot of people are having problems with missing parts. Two friends of mine purchased the full graphite set and was missing the graphite tunnel cover. I was missing the 2R Graphite support block. What's up with that? Where's the quality control that they mentioned on their web site?
#2030
Hey MDM3 where do you get those cool graphics from? The smiley going up in the space ship is great!!
Rich
Rich
#2031
Re: Losi Quality Control
#2032
Company Representative
Any one having an issue with the one-way install...???
Mine seems to be binding...
drop me an email at: [email protected]
or post here for everyone to read.....
#2033
Originally posted by JitsuGuy
Dude! I had the same problem too! Tomorrow I'm just going to get the Lunsford turnbuckle kit for the XXX-S. I was also missing motor screws. I'm using 8mm instead of 6mm...
Jits
Jits
#2034
Thanks for catching that Sydewynder. It is fixed. I will get the smilie address later. Called Losi they already shipped the turnbuckles out this morning.(so they said) From the tone must be a common problem.
#2035
I think losi quality control leaves something to be desired.
I've bought 2 losi kits a xxx and a xx.
The xx had one shock shaft with the threads machined to the wrong diameter, and the xxx had no holes in the caster blocks.
#2037
Re: Losi XXX-S Titanium Screws
Originally posted by PorscheSuperCup
Guys,
I might be able to offer a compelete screw set for the losi xxx-s, how many of you would be intrested in buying a complete set for your car???
Guys,
#2038
Can someone give me a better idea of how to set the diffs on this car? For example, AE says to tighten them up and then back off 1/8 to 1/4 turn and they're about perfect. Losi doesn't come anywhere close to that type description for the xxx-s. Please let me know what you guys are doing. Many thanks!!!!!!!!!!
#2039
Guys,
Guys,
#2040
As for tighteining the diffs hold both out drives tighten until you cannot turn the gear and you are done. Run the car they will losen up a little then tighten them or losen them to adjust the way the car drives to your liken.
Count me in on the titanium screws, got about 3 or 4 other people who would be interested also.
