Silver Can Motor Tips/Tricks
#1516
Do a search on this thread and you'll find the results of testing we did in the Lab about various motor oils and why Mobil 1 5wt was the superior performer.
There used to be a page on the Mabuchi or Johnson web site showing an exploded view of a 540 motor. Not sure it's still up there, but worth the search.
#1517
It's more tech specs than visual specs, however.
#1518
My bottle just says Mobil 1 5wt. Gray bottle, black label.
#1519
540 Factory Specs
Hi,
I purchase 2 mabuchi motors and without break-in these are the specs:
1: 11.100rpm - 1.05A at 5V
2: 10.900rpm - 1.32A at 5V
Why the difference on power consumption? What I'm searching with break-in?
What I need, hi or low current??
#1520
In classes like f1 you WILL see some slight rpm difference on the track.(although 100 to 200 difference is not that bad).
540j,is like a blind date..some are good some are..well you get the idea.
Folks with $$ tend to buy them by the batch and weed out the duds....
I have tried water dip and free air break in .
I prefer water dip at 3 volts for about 3 min.
You need to closely watch the water and make sure it does not turn dark
during this process.
When you are done, look at the brush to com contact and make sure the brush is seated on the com. oil the bushing and test again.
On my phantom dyno I usually get from 11400 to 12000 at 5v after a dip.
#1521
Thanks, but I need to know what is the optimal current consumption for the motors for free spinning on the dyno.
#1522
The best test is the track and getting laptimes. A strong motor on the bench could be weak on the track. Which is why it is good to leave the lipo in the car, get some hot laps on motor #1, then switch to motor #2.
#1523
+1, especially when dealing with brand new motors right out of the box. Amp draw is not necessarily an indicator of motor performance, as A-Ko as pointed out. Break 'em in either way until the brush faces are straight up and down against the comm, then test one against the other, keeping a close eye on motor temp (160 is ideal, 140 too low, 180 too high) and adjusting gearing as required..
#1524
Just to confirm, when you say 140, 160, 180 you are talking fahrenheit?
#1525
Yes, that is correct.
#1526
Hey ... which is the difference between 380 Tamiya Motor Silver Can, and 540 Tamiya Motor Silver can?....
Thanks a lot!
Thanks a lot!
#1527
The actual size of the motor. 380 is smaller, 540 is 'standard'.
380's are made to fit smaller motor mounts, are slower and have less torque.
#1528
Times change...
Guess this is pretty much a lost thread, uh Doc...too bad.
#1529
Not so bad. We've actually been slammed all year with orders from South Africa, New Zealand, Australia, South America and Europe. Just sent a box off to Malaysia.
The USA might not be as enamored of fast silver cans as they used to be, but the rest of the world is still in love with 'em.
#1530
I was looking to get a Red Dot who would I have to contact .
thx
thx
