Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 02-10-2009, 04:23 PM
  #4381
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Randy Caster
I'm fitting in 5000 packs with the PPD tray with no modifications to the upper deck, modifying the + terminal on the pack so I don't lose any of the upper deck's structure.
just gotta dremel just a tad in the rear of the deck near the first screw. i did it on both sides to make it equal. then again i dont run mod. (this mod is for bullet connector type lipos) this was safer for me since i already sent a lipo up in flames.
i also dremeled a little bit off the rear cross brace so i can fit my 55+ pinions on there.
Hebiki is offline
Old 02-10-2009, 05:13 PM
  #4382
Randy Caster's Avatar
Trader Rating: 47 (100%+)
At least you evened it out on the other side. I wanted to make the modification to the battery just so I don't have to worry about messing up the car's performance. If you copy someone's setup but you have a cut upper deck it's going to handle differently than how it was supposed to handle. I'm sure cars and packs will be changing before long, lipo is still new technology, so soon we won't have to worry about modifying anything.
Randy Caster is offline
Old 02-11-2009, 11:51 AM
  #4383
Hebiki's Avatar
i hear ya... ill post pix of my car and the mod.
Hebiki is offline
Old 02-11-2009, 03:01 PM
  #4384
seems to me the car was designed for 5 cell.
John St.Amant is offline
Old 02-11-2009, 03:02 PM
  #4385
Sorry .. quoted the wrong one in previous post .. This is the correct quote to the last post .
Old 02-11-2009, 04:37 PM
  #4386
The rest of the world is still using NiMh cells, and that is what is used at almost every big race now, so it's still a little soon to build the car around LiPo technology...
Old 02-11-2009, 05:07 PM
  #4387
kschu's Avatar
Trader Rating: 16 (100%+)
hi Randy, how ya doing ?
kschu is offline
Old 02-12-2009, 09:33 AM
  #4388
gansei's Avatar
Default body test
TRF 416WE body test movie
(LTC-R, Mazda Speed 6, TITAN Mazda 6)
http://www.youtube.com/watch?v=XvwuI1khooU
gansei is offline
Old 02-12-2009, 10:18 AM
  #4389
RC MARKET's Avatar
Trader Rating: 12 (100%+)
What feel & lap time ?
RC MARKET is offline
Old 02-12-2009, 01:35 PM
  #4390
Body test ..LOL..
ok.. The Mazda 6 looks twitchy but it also lookd like he didn't have a good grasp of the line , especially on the back straight and setting up for the right end of the track.
The Titan body seemed a bit more stable but also looked as if it was better due to the effect of having more track time under his belt.
Personally for carpet I perfer the R9R. It feels like it has more downforce overall. And its a kewl car and not moms grocery getter >
Old 02-12-2009, 01:51 PM
  #4391
Hebiki's Avatar
holy cow.. thats a tiny track
Hebiki is offline
Old 02-12-2009, 03:08 PM
  #4392
gansei's Avatar
Best Lap Time:
- LTC-R Body with Much-More AT 32 tire => 7.25 sec.
- TITAN Mazda6 Body with Much-More QTS 32 tire => 7.301 sec.
i felt aggressive feeling with LTC-R Body.. and stablility with Titan MAZDA 6.
gansei is offline
Old 02-12-2009, 03:16 PM
  #4393
Default belt tension
Hi guys, i was racing indoors last sunday and the question of belt tension arose...i was always led to believe the belt should be run as loose as possible without the belt slipping, which in my mind will give the least resistance on the pulleys and the bearings. However the guys i was talking to said they had been told that the belt should be run as tight as possible for maximum power delivery with no lose due to belt slap..what really got me was they had been told 10.5 should be tighter than if you had a 3.5 brushless on board..
can anyone shed some light on this question....please?
mark williams is offline
Old 02-12-2009, 06:49 PM
  #4394
I've only seen noobs running (TC5) with a tight belt.
Most others will replace it with a 416 belt.
Belt slap.... please! That thing is movin' so fast, you couldnt tell it was "slapping" . Micro seconds man... I'll give that up for efficiency any time !
Old 02-12-2009, 07:26 PM
  #4395
CraigM's Avatar
Trader Rating: 34 (100%+)
I set mine by feel, never too tight, never too lose
CraigM is offline
