Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 09-18-2008, 07:45 PM
  #2881
The cars never handle as well on Asphalt with the alloy pieces.
Check out all the pro level cars, they always run plastic.
The only cars that run alloy are people like corally, who cant get molds done correctly, and have very small production runs.
Besercoe is offline
Old 09-18-2008, 11:48 PM
  #2882
Blueman Austria's Avatar
Originally Posted by sakaguchinet
Hi,
next Month there is also the possibility for new Damper Retainers, which will fit perfectly to the HB Springs. This will also be interesting for the 501X.
I think also the WE will be a fully hopped edition with all the features, which will be used in Thailand in November (1C-1C and 1XA - 1F), Spool inside, One Piece Topdeck (like RCm said), a aluminum steering brace, which can be spacered to the regular one, and last but not least the new blue titanium Turnbuckles. About the price: I guess it will be 79.800 Yen. Pics will be available from mid October.
1XA-1F rear? Are they running realy 3,5 rear toe in
Hm why not. with the huge power of the BL motors, and the 6cell rule of the worlds, i think this cars will realy realy realy be hard to drive / handle.
Greetz Blueman
Blueman Austria is offline
Old 09-19-2008, 12:18 AM
  #2883
No, the new 1F suspension mount correspond to old 1E, so still 3
canto54 is offline
Old 09-19-2008, 11:47 AM
  #2884
TryHard's Avatar
Actually, thats wrong. The 1F is wider than the 1E. Whilst the 415 version 1E may initially seem the same width if you line it up with the 1F. However, this is a bit of an illusion, as the 416 version blocks (such as the F) have less material around the ball area, so whilst it initially appears they are the same width, the spacing between the suspension ball holes is wider.
Regards
Ed
TryHard is offline
Old 09-19-2008, 11:57 AM
  #2885
RC MARKET's Avatar
i'm saw some driver base on 1E , 1F is for spare in Control tire have more grip.
RC MARKET is offline
Old 09-19-2008, 02:47 PM
  #2886
subaru73's Avatar
Trader Rating: 42 (100%+)
Default 416
hello just picked my 416 and am looking for a good rubber carpet set up.
subaru73 is offline
Old 09-19-2008, 03:07 PM
  #2887
TryHard's Avatar
Viktor Wilck DHI 2008 is pretty much the base setup for carpet... and outdoors as well
oh, and if your new to the 416, have a look here
THard.co.uk TRF416 things to know and here
THard.co.uk TRF416 Tips, tricks, and useful stuff
HiH
Ed
TryHard is offline
Old 09-19-2008, 03:19 PM
  #2888
STLNLST's Avatar
Trader Rating: 32 (100%+)
Ling- I got ya covered on the Hara springs. Just give me a call. I have purple, black, and silver. I have been using mostly Xray springs.
STLNLST is offline
Old 09-19-2008, 05:15 PM
  #2889
subaru73's Avatar
Default 416
thank you very much ed and great site i will be spending alot of time on the site.
subaru73 is offline
Old 09-20-2008, 05:38 PM
  #2890
guinnes.s's Avatar
racing is starting soon and need to add 250grams to the 416 to rich the 1.500kg legal racing weight.because i did change over to lipo's.
any tips and info regarding distributing the weights will be appreciate.
thanx
guinnes.s is offline
Old 09-20-2008, 06:41 PM
  #2891
Low_E's Avatar
use some balancing devices to keep the car balanced at all time.
Place weights as close to the centre of the car and as low as possible, so preferable on the chassis plate (just in front of the servo, or in front or back of the battery, or behind the motor. If you use some tiny flat 20 grams-weights you can add some without disturbing the functioning of the servo and other mechanics)
What a lot of people do, is cutting out some metal plates (or pieces of lead as used by plumbers and roof-makers) and tape them to the (top of the) Lipo. This way, you just add weight where it was before (when your car was balanced with the NiMH-battery.)
Low_E is offline
Old 09-20-2008, 11:49 PM
  #2892
CraigM's Avatar
Trader Rating: 34 (100%+)
thanx
250 is a fair bit of weight. The two guys I know that are doing it with balance weights have them everywhere and their cars are heavier on the electrics side. I copied JimmyMac's idea below. With the SMC 4000 lipo, PPD stainless steel base, and 2.2oz lipo lead my car was 1496 so the rest was easy with balance weights
http://www.rctech.net/forum/electric...ml#post4288790
CraigM is offline
Old 09-21-2008, 04:54 AM
  #2893
Drifting101's Avatar
Seen as noone answered my q the last time round does a 5000 reedy pro lipo fit in a 416?
according to reedy there packs are 23.1mm high IF the nubs are in the battery slots
Drifting101 is offline
Old 09-21-2008, 06:12 AM
  #2894
You can also refer to this page when you are looking for setup:
Tamiya TF416 Setups
Arn0 is offline
Old 09-21-2008, 08:01 AM
  #2895
subaru73's Avatar
Default 416
Thank you for all of the good advise and looking forward to running the car.
subaru73 is offline
