Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 07-15-2009, 08:33 AM
  #5881
Senna Racing's Avatar
Default For those without
Tamiya 416 Suspension Block Charts
Overall Rear Toe
0 Hubs Front Block
XD XC XB XA X A B C D E F
Rear Block XD 0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 -4.0 -4.5 -5.0
XC 0.5 0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 -4.0 -4.5
XB 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 -4.0
XA 1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5
X 2.0 1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0
A 2.5 2.0 1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0 -2.5
B 3.0 2.5 2.0 1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0
C 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5
D 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 -0.5 -1.0
E 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 -0.5
F 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0
Front Arm Sweep
Front Block
Key Positive numbers = Toe / arm sweep in Negative numbers = Toe / arm sweep out
Part number designations
TRF416 style TRF415 style Evo4 style
Outlined Italic lettering Italic lettering Italic lettering + 1mm taller
Block Marking Part Number Block Marking Part Number Block Marking Part Number
XD 1XD TAM54064 1XD TAM53811
XC 1XC TAM54065 1XC TAM53810
XB 1XB TAM54066 1XB TAM53809
XA 1XA TAM54067 1XA TAM53808
X 1X TAM54068 1X TAM51069 X TAM53712
A 1A TAM54069 1A TAM51065 A TAM53713
B 1B TAM54070 1B TAM51066 B TAM53714
C 1C TAM54071 1C TAM51067 C TAM53715
D 1D TAM54072 1D TAM51068 D TAM53716
E 1E TAM54073 1E TAM53896 E TAM53717
F 1F TAM54074
A 1A (Bridge) TAM53685
D 1D (Bridge) TAM51064
Kit Settings
Front Rear Front Rear
Front Rear Front Rear Front Rear Front Rear
TRF 41X's TA05's
TRF415** 1D 1D (b) 1C 1D TA05 1A (p) 1A (p) 1A (p) 1A (p)
TRF415 MS 1A 1A (b) 1A 1C TA05-R 1A 1A (b) 1A 1D
TRF415 MSX 1B 1XB 1XB 1D TA05 MS 1B 1A (b) 1XB 1D
TRF415 MSX MRE 1B 1A (b) 1XB 1D TA05 IFS 1A (p) 1A (p) 1A (p) 1A (p)
TRF415 MSXX 1B 1A (b) 1XB 1D TA05 IFS-R 1B 1A (b) 1XB 1D
TRF415 MSXX MRE07 1B 1A (b) 1XB 1D TB's
TRF416 1B 1A 1XB 1D TB02 A (p) A (p) A (p) A (p)
TRF416WE 1C 1C 1XA 1F TB02-R A (p) A (p) A (p) A (p)
TB EVO's TB03 1A (p) 1A (p) 1XA (p) 1D (p)
TB Evo3 A A A C
TB Evo4 A A A E Key (p) Plastic kit block
TB Evo4 MS 1A 1A 1XB 1D (b) Bridge block
TB Evo5 1D 1D 1XA 1E
TB Evo5 MS 1D 1D 1XA 1E
Senna Racing is offline
Old 07-15-2009, 08:34 AM
  #5882
any one used 1XB 1D rear ???
sidecarphil1 is offline
Old 07-15-2009, 08:40 AM
  #5883
JCarr's Avatar
Thanks guys, I didn't see the chart at the bottom there.
JCarr is offline
Old 07-15-2009, 08:44 AM
  #5884
sorry havew tried to staighten that ouy but it keeps moving back across
Old 07-15-2009, 08:55 AM
  #5885
1XA-1D for me.set to 2.5 but measures 3 degree... go figure.
John St.Amant is offline
Old 07-15-2009, 09:02 AM
  #5886
Are you using a zero hub
Old 07-15-2009, 09:06 AM
  #5887
Sure am... I think thats WE kit isn't it ? At least the hubs are.
Old 07-15-2009, 09:12 AM
  #5888
wstuart's Avatar
Trader Rating: 117 (98%+)
I jusr purchased a 416we and it didnt come with a servo saver for Futaba, which i need. is it safe to just run a straight servo horn on my s9551. I noticed Hubo did it on his s9551.
Bear in mind that im not the best driver and will have a few crashes
If its a bad idea - does anonyone know a part number for a good servo saver. - I like the kimboroughs for my 12th scale
wstuart is offline
Old 07-15-2009, 09:18 AM
  #5889
This is a good one for you .. just the first site I found with a listing.
http://www.rcplanet.com/Kimbrough_Se...r_p/kim201.htm
Old 07-15-2009, 09:46 AM
  #5890
Im also using the kimbrough brand and i think 80% of ozzie racers do
This are far better than any other i have used
does the 416 not come with interchangeable splines
Old 07-15-2009, 10:29 AM
  #5891
Tamiya gives you the back of the servo saver in 3 different parts
one each for futaba,sanwa and ko
Old 07-15-2009, 01:00 PM
  #5892
TryHard's Avatar
Originally Posted by John St.Amant
Now I need Microsoft Excell.
or you could use the free Excel Viewer.
Excel Viewer
Regards
Ed
TryHard is offline
Old 07-15-2009, 01:13 PM
  #5893
adamge's Avatar
Or OpenOffice
adamge is offline
Old 07-15-2009, 01:23 PM
  #5894
syndr0me's Avatar
Trader Rating: 32 (100%+)
Google Docs on your gmail account? Keep all your spreadsheets and stuff online in a single place, accessible on any computer?
syndr0me is offline
Old 07-15-2009, 01:43 PM
  #5895
Vicko's Avatar
Trader Rating: 14 (100%+)
Mac mimi has it at the track and its under 500.00 I'm sure if u wants it
I maybe able to get an deal on it of you
Vicko is offline
