Yokomo MR4TC-BD
#7696
hi guys!!
one easy question!!
Grainger or masami edition has a different chassis from standard BD??
thanks in advance
one easy question!!
thanks in advance
#7697
umm not sure bout the grainger kit, but the masami kit has a slightly different chassi
#7698
just wondering if anyone knows what type servo saver or arm that is on graingers car in some of the pics. had mine brake this weekend. thanks.
#7699
Its just a straight KO arm by the looks of it in the pictures of Chris Grainger's car.
#7700
i found them on the ko site, thanks.
#7701
ive been running the cgm mod on my bd but will the mod work with a diff if i turn down the steering travel on my handset?
thanks
thanks
#7702
The idea of the CGM steering mod is to give more steering lock than standard, which you want when running a spool. If running a diff its still Ok but might have to much steering!!
#7703
thanks thats wat i thought..
#7705
You gain more turn-in steering and an overall more aggressive feeling
0,5 is best
0,5 is best
#7706
On Masami's lrp masters set up, when he says he uses skid angle -0.5 on the front. Does he mean hes using the 0.5 front rear block? Or does it mean hes using 0.5mm on Anti dive on the front?
just something that confused me
cheers
cheers
#7707
antidive
#7708
i have a question for john pape? what ball stud do you use on top of the c-hub with the hotbodies c-hub, hats,and yokomo steering block.
#7709
Hi
I am having problems placing my GTX with Caps on the BDM.
(i use an erg, spektrum rx and gtx)
I tried to go over the thread but to no avail. Could someone please post a picture of their electronic set up (esc with caps).
Thanks!! The pictures of brushless systems are pretty neat on the BD.
Appreciate it! Lem
Appreciate it! Lem
#7710
What is the effect of changing the pin that attaches the front hub carrier to lower arm from upper (stock) hole to lower hole (as in Masamis setup)?
