Xray T1
#5416
Trader Rating: 22 (100%+)
i want the short suspension arm setup the team drivers are using.
#5417
Registered User
pucho
hey pucho i was wondering on the front steering knuckles are you using the inner hole or outer hole for the steering link thanks jesse
#5418
Hey guys,
I am new to the Xray line of cars. I was wondering what the big differance between the Evo2 and the T1?
I looked on Xrays site and its very well put together. Just wondering what makes the Evo2 that much better.
FYI I am looking at getting this car.
Click Here
I see he is getting rid of it because he wants to run a differant chassis on carpet. Why would he is my question I guess.... I guess I should have asked him but I am open to any suggestions.
FYI I will be buying the HPI when it arrives in the states....
Click Here
#5419
Originally posted by ultragraffics
Hey guys,
Click Here
Hey guys,
Click Here
#5420
Thanks AWOL Soldier. I am in no way trying to put you down in any way. I just hope you know that. Thanks for the info and your car looks super clean. I just have to see if I can sell the one I have before I buy yours. Dont want to spend my stash for the new HPI and am sure you can understand that.
I do have one question. What the low ratio kit for? I dont know what the Xray comes with so your gonna have to help me on this one.
#5421
#5422
1.77 Gear Ratio Set
I bought a 1.77 Gear set and would like to know what other things I need to run this. Also, do I need to tighten the diff and front oneway when I put the 1.77?
Thanks!
Thanks!
#5423
Re: 1.77 Gear Ratio Set
Thanks!
Thanks!
#5424
Re: Re: 1.77 Gear Ratio Set
Originally posted by AWOLsoldier
You need the solid layshaft but that's it. As far as tightening the diffs or oneways, that depends on your track condition and driving style.
On the solid layshaft, do you change the 16t fixed pulley to 18t (the ones on the 1.77 set)? Also, the rear belt is almost hitting the motor is this ok?
Regards
#5425
the belt will hit the motor when it is slack, but as soon as you add power, it will tighten up.
It also helps if you run tires at about 2.38-2.4 ish diameter or smaller.
#5426
Re: Re: Re: 1.77 Gear Ratio Set
Thanks for the quick reply.
Regards
Regards
#5427
XXXS+ Binding in turns with Spool
My XXXS+ is binding when steering left or right with the spool in it. It doesn't do this with the one-way in it. Any suggestions why this might be happening? I like driving with the spool but this loud chattering bind is slowing me down in the turns. I have yet to run the one-way, and I don't do much braking when running this class. What effect/handling will the one -way give? Will it be anything like the Spool?
#5428
are the belts the same for the t1 and the evo 2? also if i bought evo 2 bulkheads would they work for the belt tightening on the t1?
#5430
As I understand it, pretty much everything it the same from the T1r to the Evo. All parts are interchangeable. The T1r obvoiusly has the plastic chassis and top deck, they also do the rear toe a little different(?) but you can pretty much mix and match all the parts.
