Team Associated TC5
#4366
roll out / fdr
Hi all . Looking for some help gearing our tc5 with the novak xbr system - 10.5 ex motor . We are running the same system but with the 13.5 at our track with a 39.35 roll out - fdr 5.03 - ( rubber / outdoors ) and it works great . We need to get some thoughts on the right ratio for the 10.5 . Thanks in advance .
#4367
Ste.
#4368
Has anyone purchased the aluminum outdrives? Do they come with inserts? Have any of you guys purchased any outdrives from TIR? My buddy bought the aluminum outdrives from AE and the cvds are tearing them up cause they have so much play....Any Ideas I thought maybe he threw somethin away he wasnt supposed to....
#4369
nucrptracer- if your body is using the blades then h shouldnt be tearing up the outdrives but if he is not using the bone blades then all you can really say is.......ooops! the aluminuim out drives are very good from AE. it may e confusing because with the plastic out drives you dont use the blades hope his helps
#4370
The blades are part #31238, and come with x8 in a package. I recommend buying 2-3 packages of them.
#4371
I just ordered the Aluminum outdrives but i have not been able to find the spool. Oh well hopefully my home made one will hold up for a while. What set up is a good start for 19t asphalt? I may finally get to run it this weekend someplace other than in front of the house!
#4372
#4373
Hey tc5 beilevers::::i'm looking to get a tc5 and have some questions. I've had an xray t2 and corally rdx and the things that i like about them are the hop-up parts that are available. i can't seem to find them for the tc5.any advice would be appreciated. i would like to support a american company than the over seas company's.
Thanks Mike
Thanks Mike
#4374
Mike what hop up parts are you looking for ?
If you are going to run rubber tire the only things your going to need to buy would be the rubber tire chassis and top deck ( itf chassis and itf top deck ) a spool and a one way . good to have both so you can try them out and see which is better on a particular layout.
As far as alumium hop ups for rubber tire that stuff is not needed as the material that is used to make the arms and caster blocks and steering knuckles are a bit soft compaired to the xray and corally stuff.. Which is very ideal for rubber tires and also are prone to less breakage.
#4375
#4376
Thanks Verndog. I could have sworn that i looked there!
#4377
Hey wallstreet: point taken, but not being very sharp on the track it is nice to have some rigidity, but not a manditory thing to have. thanks for the advice and also can the associated web page be more complicated to view?? or maybe it just me, another question:is the "itf" or what ever it is called just a thinner chassis and top plate??and what difference will the spool and the one-way make comparing to each other..thanks
#4378
Thanks for the help guys..........Blades on order....Have you guys ordered anything from TiR wandered how long it took to arrive in the states?
#4380
Look for Juho Levanen's setup on the Associated website. It's a very good starting point and you can tweek it to your liking from there.
