Speed Passion Cirtix Stock CLUB ESC
#226
#227
got my combo 2 days ago thanks to speedtech rc so ill hopefully have it all going in a couple of days, does anyone know what the temperature we should aim to gear the motor at? mines a 17.5t
#232
#234
mine didnt work till i reversed my throttle
give it a try see how it goes
#235
Wow, normally I would say BS to that working but I was so fed up and ready to give that I did try reversing the throttle direction to reverse and sure as hell it worked. It makes no sense because it is all input but whatever works. I am currently geared at a 4.5 because the biggest pinion I found was a 35...
I guess you can believe everything you read on the internet.
I will be running on a Small to Medium track (fast laps of 10 sec. for touring), I will report my finding after the next race. Thanks for the fast responses guys...I RCTech...
#236
not every one on forums bolws smoke up peoples arse
#237
Also, thank you TEAM for the explaination.
BTW....this step is listed on page 5, step A on the Cirtix manual. Definitely for all the FUTUBA radio. Actually, I think all the Speed Passion ESC are all listed with the same step, since the 1st version SP GT V1.0.
BTW....our team did the race last SUNDAY on a 35 x 80 small carpet track (11 or so sec per lap, sub 10 for boost up 17.5)...our general gearing is 4~4.2. The bigger/more open the track, you can throw more gear....1 adjustment we did on the club spec is the DRAG braking...since our track is TIGHT and technical, I ended up using about 20% drag brake. That helps a lot.
Keep on racing....
#238
isn't that in the directions, I think it used to be if its not.
#240
I am glad you get that figured out.
Keep on racing....
Keep on racing....
