Rc10ntc3
#2626
I use 9402s for throttle and steering in all my gas cars. Probably a bit overkill but they are very reliable.
#2627
Revealation
Do anyone know the best setup running in Revealation?
Camber, Castler, Toe in, Springs.
#2628
I have the Airtronics ERG-VB 94358Z 200oz Without the heatsink
Mounted For Both Steering & Throttle Fits Tight On the Throttle with a 1/2 mole hair to Spare With The Carbon Fiber Top Deck With the Spacers.
#2629
the 9550 fits under carbon deck and still can be lowered 2 mm more
#2630
Originally posted by ilaybrk
the 9550 is great servo for throttle you can mount under chassi it realy lowers your cg
#2631
What will i do to a nitro tc3 rtr what i mean by this is hop ups electronics, engine etc what would be my next steps in order if you can please as much as you can really helps out and what should i do anyone know any good website on nitro mantianee what i should know about nitro cleaning break into an engine etc ? any good websites?? thank for helping out.
#2632
Re: Revealation
Stock caster
Camber - start at -2deg front and rear
Toe OUT 1 deg front; IN 2 deg rear
Springs - I think it's copper front and Red rear. . . sorry, I'm at work and I just can't remember.
#2633
#2634
When it comes to servos you can never have enough. I would rather have a servo that can pull the tie-rod from the plastic ends than have aservo that cant hold the steering unless your crawling around the corner.
I run KO Fet Digitals in both Steering and Throttle.
#2635
Yes, I'm also a "you can never have enough" believer There is no such thing as overkill when it comes to servos. Good servos are an investment.
#2636
No Such thing as overkill ...... when your servo bites the big one in the middle of the race 200 oz sure seems good to me and for the $110.00 price why would you want to use anything else. my servos are 2 yrs old with NO problems other then a busted servo case i have used them in touring and 1/8 monster truck Still work as good as the Day i brought them home From The LHS.
#2637
So, if I buy a NTC3 what else should I get for it besides motor, starter box, etc...
#2638
The Steering Bearings and brake bearings and Lots of Practice racing.
#2639
NTC3Dvr, InitialD, Modellor
Thanks for your replies, I will get the Sanwa erg-vr this weekend.
#2640
spongebob
I run my NTC3 with all the stock parts[B]
knowing full well that something sometime will get broke, i just having loads of fun racing it the way it is
its still the best looking car on the track
