Old 02-26-2003, 11:03 AM   #2626
CRASH's Avatar
Trader Rating: 26 (100%+)
I use 9402s for throttle and steering in all my gas cars. Probably a bit overkill but they are very reliable.
CRASH is offline   Reply With Quote
Old 02-26-2003, 01:34 PM   #2627
Default Revealation
Do anyone know the best setup running in Revealation?
Camber, Castler, Toe in, Springs.
Audi is offline   Reply With Quote
Old 02-26-2003, 01:38 PM   #2628
Send a message via ICQ to NTC3Dvr
I have the Airtronics ERG-VB 94358Z 200oz Without the heatsink
Mounted For Both Steering & Throttle Fits Tight On the Throttle with a 1/2 mole hair to Spare With The Carbon Fiber Top Deck With the Spacers.
NTC3Dvr is offline   Reply With Quote
Old 02-26-2003, 03:41 PM   #2629
ilaybrk's Avatar
the 9550 fits under carbon deck and still can be lowered 2 mm more
ilaybrk is offline   Reply With Quote
Old 02-26-2003, 04:19 PM   #2630
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally posted by ilaybrk
the 9550 is great servo for throttle you can mount under chassi it realy lowers your cg
But wouldn't it drag on the ground if it's under the chassis?
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-26-2003, 04:26 PM   #2631
Send a message via ICQ to drive4fun
What will i do to a nitro tc3 rtr what i mean by this is hop ups electronics, engine etc what would be my next steps in order if you can please as much as you can really helps out and what should i do anyone know any good website on nitro mantianee what i should know about nitro cleaning break into an engine etc ? any good websites?? thank for helping out.
drive4fun is offline   Reply With Quote
Old 02-26-2003, 04:28 PM   #2632
Boomer's Avatar
Default Re: Revealation
Running foams?
Stock caster
Camber - start at -2deg front and rear
Toe OUT 1 deg front; IN 2 deg rear
Springs - I think it's copper front and Red rear. . . sorry, I'm at work and I just can't remember.
Old 02-26-2003, 05:32 PM   #2633
thefuzzclub's Avatar
How is it working on your car? Some say its too much (overkill) for a touring car.
thefuzzclub is offline   Reply With Quote
Old 02-26-2003, 05:50 PM   #2634
modellor's Avatar
When it comes to servos you can never have enough. I would rather have a servo that can pull the tie-rod from the plastic ends than have aservo that cant hold the steering unless your crawling around the corner.
I run KO Fet Digitals in both Steering and Throttle.
modellor is offline   Reply With Quote
Old 02-26-2003, 06:04 PM   #2635
InitialD's Avatar
Yes, I'm also a "you can never have enough" believer There is no such thing as overkill when it comes to servos. Good servos are an investment.
Old 02-26-2003, 07:34 PM   #2636
No Such thing as overkill ...... when your servo bites the big one in the middle of the race 200 oz sure seems good to me and for the $110.00 price why would you want to use anything else. my servos are 2 yrs old with NO problems other then a busted servo case i have used them in touring and 1/8 monster truck Still work as good as the Day i brought them home From The LHS.
Old 02-26-2003, 07:45 PM   #2637
Peter Busch's Avatar
So, if I buy a NTC3 what else should I get for it besides motor, starter box, etc...
Peter Busch is offline   Reply With Quote
Old 02-26-2003, 07:53 PM   #2638
The Steering Bearings and brake bearings and Lots of Practice racing.
Old 02-26-2003, 08:19 PM   #2639
NTC3Dvr, InitialD, Modellor
Thanks for your replies, I will get the Sanwa erg-vr this weekend.
Old 02-26-2003, 09:30 PM   #2640
racecar850's Avatar
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Cool spongebob
I run my NTC3 with all the stock parts[B]
knowing full well that something sometime will get broke, i just having loads of fun racing it the way it is
its still the best looking car on the track
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
