MUGEN SEIKI MRX5
#976
I have run the car once so far on a hot day 95F. The rear end was unstable and unpredictable to say the least. I was running 35 all the way around and did not have time to do any testing.
I lowered the rear lower arms hinge pin to the bottom hole reset rear drop to 8mm, Changed the shim under the rear upper arm to 1mm, set front drop to 1mm and set the acerman adjustment to the middle mark. Car was good.
We have a race at the same track and I believe there are better answers for this track....
#977
rear wing mount support coming off
I seem to have that problem every time ( both final) I got hit from the back....
the support come lose! Anyone have tips so it wont come off so easy
#978
u can try to put shims to make the round silver nut that goes into the mount thats on the car longer or free max make the mout that attaches on the rear shock tower in aluminum i just orderd it...
#979
Tried all of the above and found it was easier to live with. Only difference is i run a kick up rear arm setting, Still finding a better solution cause i cant roll the car in tight turns, it either has to be on or off power. On long sweeper it oversteer a bit wide. I have to stay on 1 clean line and cant attack any corner confidently as it will get very nervous on exit. Should i start changing springs and shock oil ????
#980
1. have u already use new tires with correct tire shore and tire split ?
2. have u already copy the basic car setup from mugen ? Or copy car setup from more experience driver ( group A ) in your local track ?
3. make sure the car's suspension arms, wheel bearings, belts, are moving freely.
After following all the above, I would do the following one by one :
Do 1,2,3 first.
And 4 second
And 5,6 third.
1. remove the kick up setting ( make it flat ), the kick up setting actually make the rear nervous.
2. shortened the wheelbase so the car can rotate faster in medium to tight corner while off throttle. ( This is the number 1 solution ).
3. slightly widened the rear trackwidth to 264mm - 265mm, with 2.5 to 3.0 degree toe in. This is to increase rear stability exiting corner on power.
4. Use middle position for front caster. More caster ( more lay back ) increase the hooking effect on sweeper while the car is on power.
5. higher roll center at rear tires, this is to reduce rear nervousness
6. lower roll center at front tires, this is to help the car turns ( more aggresive ) while off throttle.
gud luck.
I dont have mrx5. However, I have been in your situation before, and I have fixed it
2 years ago, My mrx4-r have problems like understeering at medium - slow corners, and mild oversteering on sweeper (the car hook while on power at sweeper entry ).
#981
I'm not at home right now.....
Can somebody inform me the outside diameter of 1/8 tires uncut ? front and rear please.
( the best if someone can give me the info for kawahara tires )
Many thanks
Many thanks
#982
It has a better feel now and can drive comfortably. Thank you
#983
check the following points before blaming your car's handling :
Do 1,2,3 first.
And 4 second
And 5,6 third.
gud luck.
Do 1,2,3 first.
And 4 second
And 5,6 third.
gud luck.
#984
Do 1,2,3 first.
And 4 second
And 5,6 third.
gud luck.
Do 1,2,3 first.
And 4 second
And 5,6 third.
gud luck.
#985
Kawahara Zac tires front are 70.61mm
Hope this helps you I just checked mine and they are uncut.
#987
#988
In my hometrack, top 10 drivers are mostly using mrx5 now.
Few drivers still use mrx4x and kyosho m3.
The usual finish number 1 driver is still using mrx4x.
Here a little story about mrx5 vs mrx4x :
Last weekend, the usual finish number 1 driver (mrx4x) is finished 2nd position, and the usual finish number 3 or 4 driver ( brand new mrx5 ) got lucky and finished 1st position.
The usual finish number 1 driver said to me after the race, "mrx5 is definetely better car than mrx4x, especially in high speed sweeper. I'm slower at that sweeper. He (mrx5 driver) closes the gap from that sweeper and finally pass me at lap 150".
According to him , All mrx4(x,r) cars have understeering tendencies when push to the max ( eventhough he already done 3mm wheelbase mod ).
#989
#990
