Team Magic G4
#2686
Originally Posted by NiMo
I am currently running 4 shims inside the clutchbell
What I meant to say was - add a shim and the test to see if it binds, if it does then add another shim then test it again, keep doing this and adding shims until it doesn't bind anymore, then add 1 more shim.
#2687
Originally Posted by G4S'er
I ran some numbers on the Ed trans today and found the split is 1.80 mm. If you run a 60 front, the rear should be close to 61.8 or 62. Has anyone else come up with the same or something different split?
#2688
Originally Posted by Pattojnr
Hey Sam. i too run the numbers and got this split ive sent you a little something in the mail (e), hope you like it
#2689
we are getting crossed up here, what i meant by this is i set my clutch the same way. but when i have no drag, ie about 3 shims, then i add 2 more. i found that when i added just the 1 more, when everything got to race temps, it would still have slight drag on it , so i went to adding 2 more shims. i hope to do some testing with the ED trans today as well
#2692
Originally Posted by Serpentd
Just a quick question to get some insight on everyones "shim" deal. I have a lot of different shims, from .1 to .3mm. Maybe because of me using Serpent centax and different push style clutches. So when you guys mention, "add one more shim" or whatever, you need to be more presice in your comment.
#2695
Originally Posted by Lycan
ED Transmission has a front/rear split of 1.6mm
1.8mm results in 0.32% more drive coming from the rear.
Andrew
Andrew
2.0 gives you a .9960 drive ratio. Which results in .40% more rear drive.
1.9 gives you a .9975 drive ratio. Which results in .24% more rear drive.
1.8 gives you a .9991 drive ratio. Which results in .08% more rear drive.
1.7 gives you a 1.0007 drive ratio. This results in .08% more front drive.
1.6 gives you a 1.0023 drive ratio. This results in .23% more front drive.
I started at 2mm split down to the 1.6 to see the pattern. I prefer the between the 1.8-2.0 split for a few reasons. If you are useing a front one-way setup, going down the straight the rear over rides the front causeing less drag, but through the corners if you are giving it gas the 4wd kicks in so to speak. Plus the rear tires wear faster then the fronts so you keep a more rear drive ratio for longer. I would never start or want to end up with more front drive then rear. I suppose that driving style may alter my opinion of the tire split. However a 1.8 split is the closest to a 1:1 ratio (or 1.75 is exactly a 1:1 ratio) I hope this helps and clarifies things a bit.
#2696
I have a problem with the ED transmission front one way.
seems to want to turn around on itself on throttle ( light throttle) and when the momentum is up and get to about 1/3rd throttle, it still turns on itself.
seems the right front wheel has lost drive. this is a brand new 30t front one way with the hardened Kfactory out drives. i havent got time to pull apart and inspect at the moment so i will lock the front up so no damage is done to out drive or bearing. has anyone had this problem ?
#2697
#2698
thanks for throwing one out there if your watching the cricket at the moment, then you could say the poms are in a spot of bother. but i hear you. i never actually pulled aprt the one way. so i will and see if there is a ton of grease in it thanks for the hint D, i will let you know if it was that or not. as for the rest of it its so smooth and tons of torque with the 16/21 pinions still very rich as well. later ....
#2699
#2700
The ED o/d ratio is spot on guys ,stick to 1.8 - 2.0 smaller fronts ,got the same info from Daz/Muppetracer .
Will be running car this afternoon ,will post any interesting info this evening.
