Wheels for Slash
Old 04-12-2009, 07:34 AM
Trader Rating: 31 (100%+)
Default Wheels for Slash
You guys think these will fit? It says for ALL Traxxas vehicles, but later states for "Nitro Rustler and Stampede". Please help...
http://www3.towerhobbies.com/cgi-bin...&I=LXTYP2&P=SM
vstrok is offline
Old 04-12-2009, 07:49 AM
DiFabio42's Avatar
Yes, But what tires are you thinking of putting on?
DiFabio42 is offline
Old 04-12-2009, 07:50 AM
ta_man's Avatar
Trader Rating: 168 (100%+)
If you want to use standard 2.2X2.0 truck wheels you need to get ones designed for ELECTRIC RUSTLER REAR and use them on both front and rear of the slash.
ta_man is offline
Old 04-12-2009, 10:11 AM
Just for bashing...throwing the Gator Grip ones from Pro-Line on. Should be great in the grass and dirt.
vstrok is offline
Old 04-12-2009, 10:33 AM
tennvol11's Avatar
Trader Rating: 8 (90%+)
What's wrong with the originals?? I do like those rims though.
tennvol11 is offline
Old 04-12-2009, 10:38 AM
for the power i have...the originals get no traction in loose dirt, or grass...
vstrok is offline
Old 04-13-2009, 09:53 PM
I use the Pro Line Epics beadlocks with Proline Dirt Works tires all 2.2 size. Awsome traction and still fit under the body.
Monster18t is offline
Old 04-14-2009, 04:22 AM
Trader Rating: 21 (100%+)
The stock ones are better than beadlocks and Switch tires using a 5700 BL setup and running in the grass. They look great, but don't work well in the grass. The stock ones are not that great either, but they're better than Proline Switch ones.
Some one said flat irons in another thread, Anyone using them? Tread pattern looks like it might better on grass.
Duster_360 is offline
Old 04-14-2009, 12:35 PM
I agree I don't like the switch tires that's why I went with the dirt works and I run a 6400with no probs
Old 04-14-2009, 05:28 PM
I need to find a better combo. I ordered a 36-050-4800 Medusa and plan on running 3S - got email it shipped today.
Were the beadlocks hard to put together right? Have read a lot anout how heasy its is to not do that right.
Old 04-14-2009, 05:34 PM
snowboard094's Avatar
Were the beadlocks hard to put together sight? Have read a lot anout how heasy its is to not do that right.
It is easy to put them together but if i were you i would not run beadlocks with as much power as you are putting out. It will rip the tire off the bead.
snowboard094 is offline
Old 04-14-2009, 06:06 PM
Hey, this might have already been answered, but i used the search function and couldnt come up with a thread.
But i was wondering if anyone knew if the 17mm losi adapters would work on a slash to put 1/8 buggy tires on it?
if you go to ebay and type in 17mm hex adapter, its the $18ish set of 4.
(sorry, not allowed to post links)
Thanks!
-Steve
mq1991 is offline
Old 04-14-2009, 06:10 PM
Thanks!
-Steve
R u sure you can post links? Just copy and past from the ebay sight.
Old 04-14-2009, 06:30 PM
I tried, but it said i have to have a certain number of posts to put them up... im a long time reader, and newbie joiner. lol
Thanks for the quick replay btw.
mq1991 is offline
Old 04-14-2009, 07:18 PM
http://cgi.ebay.com/TRAXXAS-SLASH-17...QQcmdZViewItem
I ran these for a while and i would recommend them.
