CRC 1/10 Pan Car
#2536
Expecting hate mail from Team Hitec any time now...Popcorn pleeeeze...LOL
#2537
Why ? Did you tell "the Hitec Police" what I said ?
Note to all of the Hitec Nazi's out there: I must have spent at least an hour on the track trying to fine tune via subtrim and whatever else I could think of, in an attempt ot FIX a car that would drift to the left, then to the right, back'n forth, over'n over (definition of insanity verified then reverified yet again), and all the time it finally proved to be the F^$#*&!@ing Hitec servo!..........There, now I feel better.......
#2538
Nope it's this one.... sorry for my intarweb faux pas....
http://www.teamcrc.com/crc/modules.p...prodID=7718958
#2540
what parts of screws do i need to install the Reverse/flat servo mount plate ..it says something about..Will need P/N 3315 - Flat servo mounts and 1424 - 1/4 in. flat head screws to reverse mount the servo..(Hitec HS-225MG servo ) please a link or some advise..thank you..
#2541
#2542
Two (2) 4-40 x 1/4" flat head screws to attach mounts to chassis plate.
Two (2) 4-40 x 1/4" button head screws to attach servo to mounts; OR, can use flat head screws with the anodized aluminum countersunk washers to add a tad better support to the servos tabs and a cleaner look.
Bill
#2544
thanks guys...
#2545
First time with a pan, Raced off-road on and off for a while but started with an 18r and a touring car to get started on-road a couple weeks back. Looking for a general setup for my new CRC Pan to run on Carpet. I will start off with the setup on the CRC site. However have no clue about rollout and esc settings. It is a smaller track 150ft straight small tight infield.
The car has the 88 tooth spur.
LRP SXX Comp ESC
Everyone here runs the rear foams cut to 57mm, so the store owner cut mine the same, and CA'd the side walls front and rear.
1s Battery
10.5 motor
I am not sure of a recommended rollout, and LRP ESC settings for this, any guidance would be awesome. One local racer recommended a 37 tooth pinion to start, but not sure if that is based on the 88 tooth spur or the old 96 (Not sure what came originally) tooth.
Thanks,
Rob
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
#2546
i am going BACK to the original servo mount set up. i tried it for 3 days now and not having any luck with it. i race mostly on a smaller track and with the reverse set up its giving me way to much steering input at slower speeds and with on power steering.
i guess im an old dog that cant learn new tricks
#2547
If so, that would explain too much steering..........
#2548
just talked to Camou and he said my issue was with trying to eliminate the bump steer... and i need to live with it
I'll get some fresh cuts and try it again.... BUT so far im not liking it
and to explain my issue its not allowing my car to push when im exiting the corner for on throttle power. im not sure if its the servo weight loading the front or due to the different ackerman?
#2549
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
Use rollout as a base since it will depend on type of esc and motor brand.
#2550
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
http://gearchart.com/index.cfm?fuseaction=chart.create
