Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 07-14-2013, 06:23 PM
  #7576
Or you can just flip the spacers already on the car from when you built the kit. Lol
Gitsum is offline
Old 07-14-2013, 07:32 PM
  #7577
jkirkwood's Avatar
Linked is the scan of the UMW705, UMW706 and UMW707 instructions. It contains both an eccentrics chart and a reference to the other holders.
https://docs.google.com/file/d/0B03C...bzA/edit?pli=1
jkirkwood is offline
Old 07-14-2013, 07:44 PM
  #7578
caguilar4's Avatar
Gotta question, what do the shims that go between the caster block and chasis do? I see that the kit comes with different choices, but don't knowmwhat the effects on handling might be...
Thanks!
caguilar4 is offline
Old 07-14-2013, 07:56 PM
  #7579
gelshocker's Avatar
Thanks for sharing. Do I need to run the hinge pin bushings, if so which ones, plastic, metal or delrin? Thx,
Also, when should one run toe-in at the hub versus at the arm?
gelshocker is offline
Old 07-14-2013, 08:22 PM
  #7580
jkirkwood's Avatar
Yes you will still need bushings. I stayed with the delrin.
As for the other question regarding toe-in, when you change it at the arm's inner position you are changing wheelbase and dog bone angle. I tend to agree with Dan Griffin's statement on the matter. http://www.rctech.net/forum/7806219-post4.html
Old 07-14-2013, 08:23 PM
  #7581
mingoglia's Avatar
Yeah, like what do you know about these toy cars?
Oh, and thanks for setting up my RB6. I spent the whole day with it yesterday and it was completely dialed. I didn't even have to switch to my Beams as my ghosted (almost bald) pressure points even provided plenty of traction. I even let Lacey drive it and even he was almost able to keep the thing on the track.
mingoglia is offline
Old 07-14-2013, 08:47 PM
  #7582
gelshocker's Avatar
Thx. If the out-B pairing is stock kit (wide 3 degrees) would you know which combo equates narrow 3 degrees?
Old 07-14-2013, 09:11 PM
  #7583
Anytime! If you ever have any questions shoot me a text ill pm you my number.
Gitsum is offline
Old 07-14-2013, 10:02 PM
  #7584
skengines's Avatar
Trader Rating: 226 (100%+)
I use the AE 12mm pistons.
GHEA makes some too, but they are about 7.00 more. The AE ones fit perfect.
Originally Posted by KalEl63
I am interested in this, what do the tapered ones do and what brand?
skengines is offline
Old 07-15-2013, 01:12 AM
  #7585
eper's Avatar
Trader Rating: 14 (100%+)
the other issue with changing toe inboard is corner entry isnt consistent do to binding in the output cups.. i used to run the wide rear and narrow front hangers on my rt5 to get more forward bite and the truck would sometimes get sketchy on entry. BUT that is a dramatic amount of toe. As i always say the only way to see how it works for you is to try it out
eper is offline
Old 07-15-2013, 03:12 AM
  #7586
Negative...the AE pistons (at least the tapered ones) DO NOT fit perfect. They are not a thick as the Kyosho pistons and need shimming to be right or your going to get an inconsistent feel. Not to mention a clicking sound from them slapping against the e clips inside.
Gitsum is offline
Old 07-15-2013, 04:56 AM
  #7587
celt's Avatar
The GHEA's as mentioned, are a perfect fit - no shimming needed.
celt is offline
Old 07-15-2013, 06:26 AM
  #7588
kyle3333's Avatar
Thanks for posting the instructions. So which configuration creates the narrow setup at 3.0? It looks like In-B/In-B, In-C/In-C, or In-D/In-D could all equal the narrow rear setup at 3.0.
kyle3333 is offline
Old 07-15-2013, 09:02 AM
  #7589
jkirkwood's Avatar
The "In-C" would equate to the narrow setup if you are currently using the UMW511/UMW512 narrow suspension hangers according to the reference provided in the document.
Old 07-15-2013, 09:18 AM
  #7590
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
+1more for the ghea pistons.
I have never had a car/ piston combo with a more perfect fit and finish.
ryanpatrickgore is offline
