Tekno RC SCT410.3 Thread
#2386
City Block 2s are the tallest tire I've ever seen. They are 1/2" taller than my Proline Square Fuzzies.
#2388
Indoor Set up working Great:
Pink Front 37.5 (Losi oil) / Green Rear 40 (Losi)
Green Front 40 (Losi) / Yellow Rear 45 (Losi) - smoother, faster clay tracks.
A Block: Center Dot
B Block: 2 Dots Up
Front Link: Inner Hole Hub, Inner row tower, Hole 2
-2 Front Camber
C Block: 1 Dot Up
D Block: 1 Dot Out & Down
Rear Link: Outer Hole Hub, Inner row tower, Hole 2
-2 Rear Camber
1/2 degree Toe Out
Center Hole Ackerman
Ride Height 25mm
Shocks laid IN on towers
A Block: Center Dot
B Block: 2 Dots Up
-2 Front Camber
C Block: 1 Dot Up
-2 Rear Camber
1/2 degree Toe Out
Ride Height 25mm
#2389
A Block: Center Dot
B Block: 2 Dots Up
-2 Front Camber
C Block: 1 Dot Up
-2 Rear Camber
1/2 degree Toe Out
Ride Height 25mm
A Block: Center Dot
B Block: 2 Dots Up
-2 Front Camber
C Block: 1 Dot Up
-2 Rear Camber
1/2 degree Toe Out
Ride Height 25mm
So what braces are you running?
Diff set up F,C,R?
Rear hub spacing?
#2390
I only run the front brace.
My diffs are 5/7/2 still from outdoors but ill be changing that soon, although they perform fine. Probably going to try 7/7/5 for indoors.
Wheelbase is 2mm F/3mm R
Oh, and I am running the 6x1.5 pistons too, forgot to mention that.
Another set up I intent to try soon is 40/40 Losi oil (37.5 AE) with Green/Green springs.
#2391
what does removing a brace do, i know it probably causes the chassis to flex easier in certain areas but how does that affect the trucks performace?
#2392
Moderator
It will lock in that end of the vehicle. For example, if you remove the rear brace, the rear of the truck will flex and generate more overall traction. If you get into high grip situations, it can make the truck feel a bit numb or sluggish. Also, if you remove the braces, you have a better chance of tweeking the chassis in a nasty crash. My suggestion: avoid nasty crashes.
#2395
I know what a low ride height does for performance, but wouldn't it be somewhat counter productive in design to have an up-swept arm angle to get the lower ride height by lowering spring heights?
At what cost does it effect other things?
It just doesn't make since to me considering geometry angles. Seems like the smarter alternative would be to mill out some drop spindle hub blocks if lowering ride height, rather than reducing travel heights with make shift setups to accommodate taller tires. Sounds like a part that needs to be considered for aftermarket deployment.
#2397
Plopping down a chunk to get a 410.3 in the next few weeks. Waiting for the holiday sale season to get this done. Hopefully tower gets some decent coupons going. Going 2s 4300 kv pro4 HD for the power plant and the Tekin g2 esc combo. Picked up a spektrum dx4c rx combo and got a Hitec mg5645 high torque servo free. Not what I wanted but it filled a need for now. Somewhat budget minded , I want to keep it around a G. Max amps are my only choice on batteries, seen a lot of guys have almost hour long runs with these. Any thing I am missing? Running on blue grooved indoor and just plain old packed dirt on the outdoors.
#2398
#2399
#2400
??? For you guys out there are you allow to race with 17mm wheel hex on your tekno like buggys wheel or you not allow too
