Rc10ntc3
#7711
Originally posted by Striker
I'm thinking of putting a Centax on my NTC3FT. I'm using a Novarossi NS12 S3. Which one should I buy and why? Cost is not a factor.
#7712
Registered User
Originally posted by sook
Hey Bob. Any luck with the internal diff gear testing? It was my mistake to assume that you were talking about the two speed. It would be nice to change the internal gearing for a large track. I know that the 710 is able to configure the internals for small track vs large tracks. Let me know how it goes.
Come on guys I need input!!! Not much on long tracks so what final drive would you guys like to see??? Bob
#7713
Let me get back to you on the final drive ratio on a big track that I would like to see. I will be out with a few old friends at the SWCS this weekend. I want to compare notes with the Kyosho and Serpent. I will let you know by late Monday. Thanks Bob.
#7716
Dumb question
Can you run 30mm foams on the ft and bk of the NTC3? Im new to foam racing and I bought 30s all around.. Do I need to go out and by MORE tyres? Thanks for the help...
#7717
BMI NTC3 Chassis
After tweaking my second AE chassis, I'm looking to get something a bit more sturdy. We race on a semi-bumpy parking lot, so the car does see some abuse. I'm hoping that the BMI will resist twisting, so I dont have to buy a new one every year. Any comments good/bad about the BMI?
Thanks in advance for any info.
Jimmy
Jimmy
#7718
There is absolutely nothing wrong with the BMI chasis. They work very well and it might be the last chasis that you purchase for the ntc3. I use the 4mm Integy chasis and has been great. It takes head on impacts, side impacts and much more with no problems. Plus it is so thick that the engine mount screws are inset so that they do not scrub off othe hex holes. No flex in 4mm. Just as good as the mugens, serpents and kyosho. Have fun with your choices. I got the chasis off of Ebay.
#7719
Re: Dumb question
#7720
BMI chassis is incredible - I have the very last Gen1 chassis made and sook is right - it's the last chassis I'll buy (unless I break down and get a new BMI chassis).
The best thing about it is that it is the strongest chassis available and takes all the flex out of the chassis. Hmm, sounds positive and it IS. It completely eliminates tweak and lets the suspension. . .suspense!
I've run a 30 minute race and banged my way through the entire thing (people just wouldn't LISTEN that I didn't want to race. . .just wanted to survive. . .) and put it on the tweak station right after - dead nuts on!
#7722
I was offered a new Barry Baker Ntc3 for 225.00. But he didn't tell me if was a team or factory team kit. Does associated make a Barry Baker team kit or just the factory team kit?
#7724
About Boomer saying your tweak was dead on after banging around for a thirty minute race. How could that be totally accurate? The reason being you would think that would throw your camber and other things out of adjustment which inturn would throw the tweak off. Any car that "bangs around for 30 minutes is bound to have a few things out of wack. Sure your tweak may still be right but there has to be other things to make the car feel out of wack.
#7725
Registered User
BMI!! The only way to fly!!
