Old 03-15-2005, 03:40 PM   #7711
AndyT 's Avatar
Originally posted by Striker
I'm thinking of putting a Centax on my NTC3FT. I'm using a Novarossi NS12 S3. Which one should I buy and why? Cost is not a factor.
Barry Baker was racing with a Yokomo centax clutch in his NTC3, so i think this one would certainly be worthwhile considering.
AndyT  is offline   Reply With Quote
Old 03-15-2005, 05:19 PM   #7712
Registered User
Send a message via AIM to bbntc3
Originally posted by sook
Hey Bob. Any luck with the internal diff gear testing? It was my mistake to assume that you were talking about the two speed. It would be nice to change the internal gearing for a large track. I know that the 710 is able to configure the internals for small track vs large tracks. Let me know how it goes.
I've sent gearing out to local machinist friend, he considering the task now. They will probably be bronse. He's also thinking about changing the pitch to make it alittle easier to make if he changes the pitch then higher or lower ratios will be available. This will take alot of testing to make sure it works in the stock ratio first, then lower and higher.
Come on guys I need input!!! Not much on long tracks so what final drive would you guys like to see??? Bob
bbntc3 is offline   Reply With Quote
Old 03-15-2005, 07:26 PM   #7713
Let me get back to you on the final drive ratio on a big track that I would like to see. I will be out with a few old friends at the SWCS this weekend. I want to compare notes with the Kyosho and Serpent. I will let you know by late Monday. Thanks Bob.
sook is offline   Reply With Quote
Old 03-15-2005, 07:28 PM   #7714
revzalot's Avatar
Yes definately get final drives for large tracks.
revzalot is offline   Reply With Quote
Old 03-15-2005, 07:38 PM   #7715
Yes BB, as we all know one of the problems with the car is top end.
CHUCKMANDO is offline   Reply With Quote
Old 03-16-2005, 12:32 AM   #7716
losispeed's Avatar
Default Dumb question
Can you run 30mm foams on the ft and bk of the NTC3? Im new to foam racing and I bought 30s all around.. Do I need to go out and by MORE tyres? Thanks for the help...
losispeed is offline   Reply With Quote
Old 03-16-2005, 05:05 AM   #7717
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Default BMI NTC3 Chassis
After tweaking my second AE chassis, I'm looking to get something a bit more sturdy. We race on a semi-bumpy parking lot, so the car does see some abuse. I'm hoping that the BMI will resist twisting, so I dont have to buy a new one every year. Any comments good/bad about the BMI?
Thanks in advance for any info.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 03-16-2005, 07:22 AM   #7718
There is absolutely nothing wrong with the BMI chasis. They work very well and it might be the last chasis that you purchase for the ntc3. I use the 4mm Integy chasis and has been great. It takes head on impacts, side impacts and much more with no problems. Plus it is so thick that the engine mount screws are inset so that they do not scrub off othe hex holes. No flex in 4mm. Just as good as the mugens, serpents and kyosho. Have fun with your choices. I got the chasis off of Ebay.
Old 03-16-2005, 02:59 PM   #7719
AndyT 's Avatar
Default Re: Dumb question
You can definitely run 30mm foams on the rear of a FT NTC3....never tried anything but 26mm on the front of mine.
Old 03-16-2005, 03:23 PM   #7720
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
BMI chassis is incredible - I have the very last Gen1 chassis made and sook is right - it's the last chassis I'll buy (unless I break down and get a new BMI chassis).
The best thing about it is that it is the strongest chassis available and takes all the flex out of the chassis. Hmm, sounds positive and it IS. It completely eliminates tweak and lets the suspension. . .suspense!
I've run a 30 minute race and banged my way through the entire thing (people just wouldn't LISTEN that I didn't want to race. . .just wanted to survive. . .) and put it on the tweak station right after - dead nuts on!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 03-16-2005, 07:41 PM   #7721
bigtez's Avatar
Default K factory Centax Clutch
Has anyone used one of these before?
Are they any good?
bigtez is offline   Reply With Quote
Old 03-16-2005, 08:09 PM   #7722
yodace's Avatar
I was offered a new Barry Baker Ntc3 for 225.00. But he didn't tell me if was a team or factory team kit. Does associated make a Barry Baker team kit or just the factory team kit?
yodace is offline   Reply With Quote
Old 03-16-2005, 08:59 PM   #7723
huskerfreak's Avatar
Who ever is selling you the kit probably thought that is what it was called. I am sure it is the same thing. Barry Baker is on the box of the factory team version and it has his signature next to his picture. Kit # should be 2033
huskerfreak is offline   Reply With Quote
Old 03-16-2005, 09:04 PM   #7724
About Boomer saying your tweak was dead on after banging around for a thirty minute race. How could that be totally accurate? The reason being you would think that would throw your camber and other things out of adjustment which inturn would throw the tweak off. Any car that "bangs around for 30 minutes is bound to have a few things out of wack. Sure your tweak may still be right but there has to be other things to make the car feel out of wack.
Old 03-16-2005, 09:21 PM   #7725
Registered User
BMI!! The only way to fly!!
