Like Tree5Likes
SC10 4x4 Thread
Old 12-04-2011 | 08:14 PM
  #11896
IRM616's Avatar
Originally Posted by lawnmowerjockey
Not real sure. I ran around 15 packs through it with no probs and temps were always good. I was a couple of minutes into a run when the truck just quit and the esc started smoking. When I hit it with the temp gun both motor and esc were barely warm. I sent it back and Tekin replaced the circuit board and said it was of no fault of mine. Anyway, got it all hooked up and back together last night. It calibrated fine but shows error code of wrong motor type so I checked it and it is set to brushless then it lights up for normal opperation. When I hit the throtle the led's light up as they should but no power to motor so then I cut the power off at switch and try again and the whole things starts over with wrong motor selection. I had 3 guys at track (all vets who own or have owned Tekin) look at it and no one could figure it out.
That sucks...I would call tech. Good luck with that
IRM616 is offline
Old 12-04-2011 | 08:27 PM
  #11897
SourDieselX's Avatar
couple pics of mantis' truck
not his shortcourse truck but his 1/8th scale Caster
all pics were taken at the Pro RC Series a few weeks back
SourDieselX is offline
Old 12-04-2011 | 08:31 PM
  #11898
Wild Cherry's Avatar
That yellow pipe ?
it looks smooth , no ribs ....
Am I seeing that right ?
Wild Cherry is offline
Old 12-04-2011 | 08:43 PM
  #11899
That yellow pipe ?
it's ribbed, just the blur you see, photo was adjusted to snap only the object and not the surroundings.
Old 12-04-2011 | 08:45 PM
  #11900
TY
Old 12-04-2011 | 09:14 PM
  #11901
MantisWorx's Avatar
Originally Posted by Resqnu
Can you explain what they do and what makes them better?
Also, do you guys suggest running a underbody tray when running outside?
http://www.rctech.net/forum/electric...they-work.html
MantisWorx is offline
Old 12-04-2011 | 09:18 PM
  #11902
MantisWorx's Avatar
Originally Posted by IRM616
Can you tell me about 2 stage piston and garodiscs? Any a site were I can get it. Thanks
www.RCShox.com
Old 12-05-2011 | 06:10 AM
  #11903
lodhammerdin's Avatar
Originally Posted by Chad Smith
What motor are you running with that esc?
The best part about those speed controlers is some of them perform just as well as the more "high end" electronics for a fraction of the price
Anyone see the 1/10 sensorless brushless system from orion that looks like a ezrun esc with orion stickers on it?
I run LRP x12L 550's or x12 540's. 550 for a large open track and 540 for a smaller, tighter track.
lodhammerdin is offline
Old 12-05-2011 | 07:51 AM
  #11904
What motor size works better for a small technical jump and a bigger track that is less technical? 540 or 550?
J-RO is offline
Old 12-05-2011 | 07:59 AM
  #11905
Chad Smith's Avatar
A 550 will get you around any kind of track. If you go with a 540 it will suffer and not perform as well as a 550 on a bigger track.
Chad Smith is offline
Old 12-05-2011 | 08:07 AM
  #11906
Thanks for the help. I think I'll go ahead and order the Xerun. The worst part about all of this is that I just installed the 2 stage pistons and garodiscs and can't get to the track to try them out.
What you described sounds like it may be a bad sensor circuit. If the speedo has a sensorless mode, try that if you haven't already. Might at least get you going until you get a new speedo.
Either the LRP SXX TC Spec or the HW will both work with that motor. Actually running a V1 TC Spec right in my Sc10 4x4 and it's been great with both SC4X 6.5 and 4.5 motors. Have been running HW/SP in other crs for almost a year, very happy with it. Like Sym, I prefer the SP software, and it's also easier to find setups for. If you can find the HW/SP 120 amp 2.0 Pro, that's the best speedo for 4wd SC. Lower turn limit than the 2.1, but may be hard to find.
cjtamu is offline
Old 12-05-2011 | 08:32 AM
  #11907
Chad Smith's Avatar
I have a chassis brace and I know that it is used to help with flex and belt slack. But once I install the brace should I loosen the tension on the belt?
Old 12-05-2011 | 08:50 AM
  #11908
I left mine where it was before I installed the brace, have not had a problem. I do plan on probably loosening it some though...try to remove some drag. Just afraid to loosen up a hard used belt. I'm still on the same belt that I started on a couple months ago. It's got a lot of laps on it.
outlawrcgraphic is offline
Old 12-05-2011 | 09:15 AM
  #11909
Talking
wll i gotta say that i am fallin in love with my sc10 4x4. i was strugglin gettn the rear to hook on [power but i solved the mystery.last fri nightrs race i put a lap on the guy who usually laps me twice. It felt great. 4wd buggy fast laps were around 14.5 ,and my fast lap was 14.008.truck is really comin alive.if i couild find the right tire then its game over
bradp29 is offline
Old 12-05-2011 | 10:20 AM
  #11910
JayL's Avatar
Originally Posted by R Doyel
I bought my kit last night! I have it spread all over the kitchen table......the kids are still in bed. I feel like it's Christmas morning!
I haven't built an off-road kit since my RC10 worlds edition.......1994?
Any tips for the build?
lol Doyel we get to race in 4x4 now?I haven't been running VTA, too much offroad
I was the fastest AE 4x4 at the big opening race at Holeshot, qual'd 3rd, my basic setup:
32.5 F+R
yellow front springs
2.0 sways F&R
30k front diff oil
5k rear diff oil
Garodisk as rear slipper pad and AE HD as front slipper pad
JC Hazard wheels with gold barcodes ground smooth
I have been running a 6.5T 540 can motor with a 13mm rotor
be prepared to be hit on the inside rear bumper by many a Losi
JayL is offline
