Clockwork Racing Engines and Products... >
Old 11-20-2011 | 07:59 PM
  #3781
J.Sears's Avatar
Originally Posted by rageworks
I always used some "JB Weld" epoxy to glue the insulators onto
my O.S. v-spec carbs. Just spread a thin layer of the epoxy inside
of the insulator with a Q-Tip or flux brush. Slide it onto the carb body
until it seats all of the way onto the carb body. Make sure you clean all of the excess wet epoxy off of the carb body and bottom of the insulator with a damp rag. Let the epoxy set-up overnight before you install the carb on
the engine.
I have tried the o.s. carb on quite a few different engines and found
the engines always gained a little extra runtimes. Let us know if the
Werks engine gains any extra runtime using the o.s. carb.
Thank you rageworks! I'll give that a try and see how it holds. I've heard it makes the B5 tune real nice. The engine runs real good but it won't hold a steady idle no matter what I do to it. I'm not a great nitro tunner but I can tell something is not right with it so I figured I'd try a different carb to see if its me or the carb. I will let you all know how it does. Thanks again!
J.Sears is offline
Old 11-20-2011 | 08:03 PM
  #3782
Maximo's Avatar
if your swappin carbs be sure to use the Werks base O-ring instead of the OS one.... Good luck and let us know !
Maximo is offline
Old 11-20-2011 | 08:07 PM
  #3783
Maximo's Avatar
Originally Posted by TX_Punisher
Interested in this as well.
P5 has gobs of torque and midrange...and a good top end runout..This engine is very punchy
Plus4T has great torque, but a smoother pull thru the powerband then the P5, very good on fuel
B6 has a good bottom and the powerband really blossoms in the midrange and top end, the engine has some really serious top end run out..... Extremely good on fuel....
Maximo is offline
Old 11-20-2011 | 08:24 PM
  #3784
Muggydude's Avatar
I switched to the Os carb after two gallons, and was much happier. (Werks b5 pro)
Tunes MUCH easier, and just seemed to perform better. The run time was about the same, maybe a little less. Still got 11-12 minutes when tuned right.
Muggydude is offline
Old 11-20-2011 | 09:46 PM
  #3785
savagesam's Avatar
Funny enough I swithed both my werks b5 pro & b6 pro over to novarossi carbs as I just kept getting inconsistent tunes that where perfect one day then way off later that same day.....been good as gold on a novarossi carby
savagesam is offline
Old 11-21-2011 | 12:51 AM
  #3786
which OS carb should I use on my b6 pro
dougwalter911 is offline
Old 11-21-2011 | 06:08 AM
  #3787
TX_Punisher's Avatar
Thanks. Will the Plus4T or B6 have more bottom assuming similar pipes are used, say a 2058.
Sounds like the B6 will be the best on fuel when comparing the three and will have the most top.
TX_Punisher is offline
Old 11-21-2011 | 06:14 AM
  #3788
Maximo's Avatar
Plus 4 has more low end grunt...nearly equal top, but is smoother on dlivery and similar runtimes... The B6 is slightly softer off the bottom with a stronger midrange spoolup and also phenomenal mileage....
Maximo is offline
Old 11-21-2011 | 06:52 AM
  #3789
hookem34's Avatar
+100. Same result for me when I sitched over to my OS long needle carb.
hookem34 is offline
Old 11-21-2011 | 08:58 AM
  #3790
Chris Peralta's Avatar
I ran engines from this same factory back in 2006. Back then they needed Nova carbs too.
Chris Peralta is offline
Old 11-21-2011 | 09:00 AM
  #3791
kgombe's Avatar
pop corn time.. lol
kgombe is offline
Old 11-21-2011 | 09:15 AM
  #3792
Maximo's Avatar
everyone has their preferences... No popcorn needed.....
Maximo is offline
Old 11-21-2011 | 09:24 AM
  #3793
J.Sears's Avatar
I'm not saying the werks carbs are no good or anything like that I just wanna try an OS carb to see how it does. I would never say anything bad about werks engines because they are great. I have 3 B5's and they have all ran very well but there's something about this new B5 pro with the idle on it.
J.Sears is offline
Old 11-21-2011 | 09:39 AM
  #3794
What OS carbs can I use on my B6 Pro. If you have model #'s that would help me out a lot. thanks
Old 11-21-2011 | 10:07 AM
  #3795
J.Sears's Avatar
I'm not real sure. I was told to use the OS speed carb. I'm sure the vspec carb will work also.
J.Sears is offline
