Like Tree5Likes
SC10 4x4 Thread
Old 10-31-2011 | 07:25 AM
  #9856
SS LS1's Avatar
Originally Posted by CraigMBA
Mine looks exactly like yours. Never an issue.
Thank you for easing my concerns, i'm looking forward to getting this truck on the track with all the great mods everyone has done here.
SS LS1 is offline
Old 10-31-2011 | 09:23 AM
  #9857
SS LS1's Avatar
Originally Posted by BLbound
Nice pics, thanks for sharing SS! I wanted to ask you what hexes are you running? They look pretty wide and aluminum...hmmmm very curious . Thanks!
The truck has several pieces from STRC which include the drive hexes, front and rear hinge pin braces, idler pulleys, motor heart sink plate and the most impressive (IMO) is the quality of the shock bodies and upper spring perch. Makes adjusting the ride height easy with the large knurled threaded collars. I also have a set of STRC rear bearing blocks that are not installed yet that are also very high quality. The STRC stuff has better quality (fit/finish) than other aftermarket components I have used from other vendors in the past.
Photo showing the shock bodies.....and the hex drive just barely.
SS LS1 is offline
Old 10-31-2011 | 10:40 AM
  #9858
1Fastpede's Avatar
i wanna know if the strc collars center the spring better on the body so spring rubbing is less of an issue.
1Fastpede is offline
  #9859
SS LS1's Avatar
Originally Posted by Slashdrivr
I have a feeling I'll be seeing that truck alot...looks good Greg
Hopefully not just from your rear view mirror , I just hope to get up to speed quickly driving a 4x4 so I can run with you, Rich and Lee competitively on the track.
SS LS1 is offline
Old 10-31-2011 | 10:41 AM
  #9860
Originally Posted by SS LS1
Ok a question for you guys and the MTK slipper basket, anyone have any issues with the outer slipper plate rubbing on the outside edges of the aluminum basket due to misalignment? I have the vented slipper outer plate and once all assembled the slipper disk it's not centered within the MTK basket and looks like it will rub on the basket during use (haven't run the truck yet).
I have a brand new spur gear that I have tried to flip over and also clock to different positions when assembling the slipper assembly with the basket and it makes no difference. The outer slipper disk it's not centered over the adjoining pad and basket.
Oddly the spur, slipper disk and basket all appear to run true when spun by hand.
You can see the overlapping of the slipper disk over the basket edges in one photo, then I rotated the assembly 180° and took another photo to show areas the slipper it's located well within the basket edges.
Is this normal for everyone else running slipper setup or should I be concerned?
Mine's close but it's not touching the basket. I'd be worried about it not clamping the pad squarely if its hanging up on one side. Nothing 30 secs with a dremel won't fix tho.
Slashdrivr is offline
Old 10-31-2011 | 10:46 AM
  #9861
SS LS1's Avatar
From what I have seen (and feel by playing with the suspension) they are better than the Factory Team shocks regarding spring rub on the shock bodies. Only time will tell.
SS LS1 is offline
Old 10-31-2011 | 12:30 PM
  #9862
Vegatron75's Avatar
Went racing on a big gnarly outdoor track last weekend. Check out the winning Losi' "wing".
He wouldn't take it off, he told me that "once I put one on, I'd never take it off". Those losi guys....
Vegatron75 is offline
Old 10-31-2011 | 12:36 PM
  #9863
CoyoteSlash's Avatar
CoyoteSlash is offline
Old 10-31-2011 | 12:39 PM
  #9864
symmetricon's Avatar
Is that even legal, do you guys care that he is running a wing? We have a guy that has an actual 1/8 buggy wing attached to his scrt. Its not a big deal cause he isnt going Tq and win. But if he did, people would be talkin....
symmetricon is offline
Old 10-31-2011 | 12:47 PM
  #9865
It's not legal. It's not a Item designed for the Truck. or a 3rd party Short Course Body with it. (even then ROAR would decline it's legality.)
Old 10-31-2011 | 12:58 PM
  #9866
We had people get in an uproar over how many/how big of holes you could cut out of the back or windshield. If someone threw a wing on like that and wouldn't back down it would end in a DQ and the resulting skirmish would be on youtube the next day. lol
Krio is offline
Old 10-31-2011 | 01:01 PM
  #9867
PanicRev's Avatar
I see the problem Vega, next time try a redbull can. They are dialed.
PanicRev is offline
Old 10-31-2011 | 01:07 PM
  #9868
Vegatron75's Avatar
LOL, The toe-in on the MD can was way off,hahahha. It actually looks like that weiner dog is about it piss on it.... he was feeling the same as I was ,,, piss on it....
I kept mentioning the wing to dude, we wasn't going to take it off for nothing. The track owner, behind 2nd place guy, didn't say anything so ?????
Old 10-31-2011 | 01:08 PM
  #9869
SourDieselX's Avatar
I'm not really sure I dig the whole wing, the track does state that they follow HARC rules and HARC follows ROAR, i'm sure it gives him a bit of an advantage but not really sure.But then again, ROAR also states no side window cut outs and most of us have them.
SourDieselX is offline
Old 10-31-2011 | 01:31 PM
  #9870
What the hell...he'd be laughed off the driver stand...
