Serpent 811E Buggy Thread >
Like Tree5Likes
Old 10-23-2011 | 02:49 AM
  #406
bigjayjay1's Avatar
Originally Posted by Bonadona
I did exactly what you did and followed the "new shimming instruction" sheet and I thought the same thing. I guess I will trust them. Lol
Frank how did you shim yours was it tight did it break?it thinking about pulling one shim per diff seems to tight.
bigjayjay1 is offline
Old 10-23-2011 | 04:43 AM
  #407
Frank L's Avatar
I shimmed as per the addendum in the I structions and the front was a little tight. Seemed to losen up after a few packs.
The car has tons of steering. It is fast and nimble. I like it. I'll have some video up next week gotta edit it together. I messed with setup a little bit but it needs more work. I went to a 1.8 sway bar in the rear, 2.3 in the front and moved the bubs foreward. The read is still a little loose for my liking. Suspension is very plush and overall the and has a great feel. Once again you hit it out of the park serpent
Frank L is offline
Old 10-23-2011 | 07:25 AM
  #408
frank- it is sound good and i cant wait see a video .
taztal3 is offline
Old 10-23-2011 | 07:57 AM
  #409
Bonadona's Avatar
Are there any pistons you guys have found to be better all around than the kit pistons. Not that these aren't fine just wondering if in some of your nitro testing you guys have found something you like better. Frank that's good news for a first time quick shakedown, sounds like the buggy hits all the key points, just some fine tuning to your driving style is all that's left.
Bonadona is offline
Old 10-23-2011 | 09:02 AM
  #410
chicky03's Avatar
Glad you like the car Frank!!
The looseness will probably go away in a race or 2. The rear drive shaft pins need to get a nice flat spot in them before the car really gets to its full potential.
chicky03 is offline
Old 10-23-2011 | 09:32 AM
  #411
Frank L's Avatar
Swapped some springs around and had the mad scientist dial me in. Car is great now.
Frank L is offline
Old 10-23-2011 | 11:33 AM
  #412
Default K
Video please
muaythai is offline
Old 10-23-2011 | 04:36 PM
  #413
joel804's Avatar
So what did you and the mad scientist do. Please tell.
joel804 is offline
Old 10-23-2011 | 04:41 PM
  #414
ShtLuck's Avatar
just curious fellas, i just got a nitro roller with a ton of spares. anyone converted one yet?
i would like to get a serpent e buggy or convert this one.
ShtLuck is offline
Old 10-23-2011 | 05:09 PM
  #415
The Serpent machined delrin tapered pistons are the best! The 8 hole pistons, drilled out 1.3mm seem to be the standard starting point.
I'll have my car ready for testing on Tuesday night up at ARCs. I think Chicky needs to come out to help me set it up.
Stealth_RT is offline
Old 10-23-2011 | 05:51 PM
  #416
Bonadona's Avatar
Thanks, that's what I was looking for. Please let us know how it goes Tuesday and what changes you make. Thanks again.
Bonadona is offline
Old 10-23-2011 | 07:16 PM
  #417
Frank L's Avatar
Originally Posted by muaythai
Video please
The video will be ready later this week
Mostly springs. Stiffer in the front and softer in the rear. Ended up with losi grey inthe frot and losi silver in the rear. Rear hubs forward. 6-6 in the rear for plate is good for a dusty loose track and 4 up for a high bite track. Steering junkies will love this car.
Frank L is offline
Old 10-23-2011 | 09:17 PM
  #418
I did not do the shims in the diff like the add. said. It was way too tight. I shimmed FR/RR to be no backlash but no binding.
RAN the car for the first time at the track and here are my initial observations. (compared to my Mugen MBX6E)
Pros:
-Smooth shocks that handled a rutty track very well.
-The kick up on the chassis was noticeably better on jumps especially when landing a jump a tad short/ on the apex of the jump landing. My Mugen used to ricochet violently up if I came a few inches short of back siding a landing. The kick up on this chassis made those mistakes vanish like magic.
-I could carry more speed in turns
-When I did crash I had a knack for always landing on my wheels. 9/10 crashes magically ended up on my wheels where on my Mugen it was a 50/50 thing.
Cons:
-Default setting had the rear end sliding out
-Center diff might have been tad too low as my front wheels flared up/unloaded on any acceleration above 50% throttle. (did stock 5/5/3. May try 5/7/3 then 5/7/5
-Rear shocks felt stiffer than front. This could have contributed rear sliding out.
I'll try changing to slightly heavier front shocks and lighter rear shocks springs. And after that I may try a softer Anti-Roll bar in rear to get more roll and traction.
What do you guys thing? What are your observations of your 811e at the track?
jasonwipf is offline
Old 10-23-2011 | 09:35 PM
  #419
porkchop's Avatar
form what i know about the car run stock with orange front spring prurple rear
porkchop is offline
Old 10-23-2011 | 09:42 PM
  #420
Frank L's Avatar
I did swap the swaybars out too 2.3 front and 1.8 rear. It does push just a tad but I like it to push just a little bit.
Frank L is offline
