Serpent 811E Buggy Thread
#421
Help a noob out, what batteries are people using/going to use, with this buggy? I want to get the 4mm banana style batteries since it seems like that's what the tray was designed for but which 2s types would be smart to look at buying?
#422
Here's a link to their thread.
#424
#425
Since thunder power does not make a battery with a bullet connector I'm going to give there high velocity packs a try. I have been hearing good things about them. Thy typical style with deans connectors are just not happy with the door system on this car.
#426
I just pm'd him for details. I think I'm going to go off your guys rec and order a pair of these. Anything else I'll need besides the kit,esc,& motor? Also bigjayjay1 what motor are you planning on running in the serpent? I will be running on indoor clay, med size track.
#428
Current setup: 2 6000 60 C / RX8 / 2050 Buggy for indoor you should go with a lower KV motor pending on track also plan to purchase a lower KV since these packs have a lot of kick
#431
#432
You need everything in between the front and rear transmission including the front and rear center drive shafts, chassis braces, body. Also the Ebuggy has all the updated bearing couplers, hubs, diff gears etc. It would not be cost effective, I think it would be better off selling your nitro buggy and getting a Ebuggy then you would have a totally new car!
#433
5Likes
