SC10 4x4 Thread
#8881
The 4x4 and the 2wd internals are of different pitch, so it is impossile as thing are now to switch between the two. I ordered the aluminun hard anno idler gear. I should have it for this race weekend, so we will see if it can handle the power. I will also find out if the hard anno diffs are worth the money.
#8882
No problem. The 2wd is 48p while the 4x4 is 32p so.....
But if Mantis hasnt blown the idler yet with how hard he is on it, it may just have to do with the tightness of the slipper and how hard you are on throttle when you land. Either way, I am loving tis truck and will stick with it till the end.
I do feel that the engineers at AE will revise the truck until it's money. itwould be nice for AE to throw us a bone every once in a while and let us "commoners" know whats up, what to look forward to, and how it will help more races be won.
#8883
Yeah. I just was browsing, saw it. And quickly asked while there were so many people viewing the thread. I didn't even care to read the details on the idler, The pics were enough to see it wasn't 48p cause it's such a close up.
My brain fart for the day.
Like I said, I agree. It'd be nice to be thrown a "thanks for sticking with it, we're listening" bone. Fo Sho.
My brain fart for the day.Like I said, I agree. It'd be nice to be thrown a "thanks for sticking with it, we're listening" bone. Fo Sho.
#8884
15T on the small track 35'x90'...16T on the large one 85'x120'...
Power hungry motor tho...32-3300 mah compared to 23-2400 mah with the 1410 in a 6 min race...
MMP in Smartsense w/10 deg timing. ESC/motor both coming off @ 110-120.
#8885
well crap, no way i can make a 10min main with saddles then, hmmmm i cant believe it draws more than my novak 550????
#8887
Only people with a reinforced slipper are, not us all.
There's some of us who don't want/need that extra slipper grip while running pinned.
That extra grip is what kills the rear transmission.
Remove the basket, leave the garodiscs/HD pads, lighten the pressure on the pads and you're good to go.
It's a tradeoff. Basket or pinned. Not both.
#8888
That extra grip is what kills the transmission.
#8890
I've ran (until right now) five hours of 2/3+ throttle on my track, with a slightly loosened slipper setup, the gears still look like new, no noises, no nothing (except for the massive acceleration).
People using a basket were ruining the rear gearbox with less than an hour of running.
Care ellaborating your statement?
#8891
I think it's time enough seeing everyone else's comments
Pinned Top Shaft Drivers
This is a warning from here on out.
Do not run your Pinned SC10 4x4 with the slipper settings you are used to.
Due to the pinned fix, the slipper should be treated as it states in the manual. Once pinned, go to factory settings on your slipper clutch and begin tuning from there for minimal slip.
Failure to do this will result in Stripped Idler Gears and further repairs.
(I am not trying to be dramatic. It just is easy to search and find this if entered in the thread correctly)
#8892
#8893
People give full pressure to the slipper, and doing that with the pinned shaft just (as you said) BLOWS transmissions up.
#8895
5Likes
