New Hitec Servos!!
Old 10-06-2011 | 10:59 AM
  #61
LOOK AT THIS
hobbyking 87.75$
BLS-2209 is a High Voltage (7.4V) Brushless Digital Servo featuring Titaium gears and an Alu heat sink case. The BLS-2209 includes a heavy duty servo horn set.
Specification:
Weight: 66 grams
Dimensions: 54.50 x 20 x 39 mm
Torque @ 6V: 18 kg/cm
Torque @ 7.4V: 22 kg/cm
Speed @ 6V: 0.11sec / 60 deg at no load
Speed @ 7.4V: 0.09sec / 60 deg at no load
Alu Heat Sink Case, Titanium Allow Gear, Brushless Motor, Digital
Tim3 is offline
Old 10-06-2011 | 01:31 PM
  #62
Integra's Avatar
Originally Posted by Tim3
LOOK AT THIS
hobbyking 87.75$
Specification:
Weight: 66 grams
And this means what to Hitec ?
Are you thinking this is a knock off of What has yet to be released By Hitec ?
Integra is offline
Old 10-07-2011 | 05:02 AM
  #63
Till the Hitec comes out, I'm getting one to tryout. For the price of one Hitec I can get two.
Tim3 is offline
Old 10-07-2011 | 08:43 AM
  #64
madac's Avatar
It means that the Bluebird Brushless Servo would be a better buy than spending $160-$200 for a Hitec brushless servo. It does look like the Hitec high voltage servos though.
madac is offline
Old 10-07-2011 | 09:01 AM
  #65
Integra's Avatar
Did you bother to read up on these new servo's. Obviously not as you would see there's some pretty substantial gains to be had. Futaba Nor Any other BLS Servo Mfg has released any info pertaining to their Stall #'s where as Hitec Is At the Front of their game even going as far as Testing Their Product Vs their Competition's Right in front of Consumer's and Obviously BLOWING them out of the water All the while consuming 1/5 the power. Unfortunately that will come at a Price and while some might not see it being worth it, I can guarantee you A lot of people Will.
Integra is offline
Old 10-07-2011 | 10:57 AM
  #66
This is what Im looking at for a 30cc to 50cc 3D gaser.
I would use two of these in the new 1/5 losi 4X4 steering
Integra, I would have bought one of the Hitec's had they came out when they said it would.
So, for the time being i'll get this one to try out.
Weight (gram) 66 g / 2.33 oz
Size (mm) 40.5 x 20 x 39 mm / 1.59 x 0.79 x 1.54 in
Torque at 6.0V 18 kg-cm / 250 oz-in
Torque at 7.4V 22 kg-cm / 306 oz-in
Speed at 6.0V (sec/60°) 0.11
Speed at 7.4V (sec/60°) 0.09
Ball Bearing Yes. Dual
Type Gears Titanium Alloy Gear
Motor Type Brushless Motor
Middle Case Aluminum Alloy Heat Sink
Operating Voltage Range 4.8V to 8.5V (2 cell Li-Po / 6 cell Ni-MH Compatible)
Operating Temperature Range -20°C to +60°C
Idle Current 11mA
Running Current 6.0V 340mA / 7.4V 350mA
Stall Current 6.0V 5140mA / 7.4V 5923mA
Dead Bend Width 1us
High Response System (HRS) 3ms
Direction Clockwise / Pulse Traveling 1500 ~ 1900us
Horn / Gear Spline 25 teeth
Connected Cable Length 300 mm (11.81 in)
Connected Housing JR system
Power Push Chips Mos-FET
Wire Info
Brown Wire = Battery Negative
Red Wire = Bettery Positive
Orange Wire = Signal
Attached Thumbnails New Hitec Servos!!-bls-2209.jpg   New Hitec Servos!!-bls-2209-box.jpg
Tim3 is offline
Old 10-07-2011 | 01:38 PM
  #67
madac's Avatar
Can you even prove they are better servos? or did the here/say prove that for you. You cannot say they are going to blow the competition out of the water without proof can you? All your going by is a sneak peek blurb about the new Hitec brushless servos and hear/say and you must be a die hard employee or just a fanatic for Hitec. Have at'er. They're all yours but don't complain if they break after all the supposed testing you say they have done and blowing the competition out of the water, yeah I'll believe it when I see it. They'll probably be pretty good servos but they were supposed to be out in June and now it's October!!! If I can save and get a servo that is just as good for half the price I will but you also have no proof that these Bluebird servos are no good. Whatever. Do what you want and say what you want not everyone can be a robot but you pull it off pretty good.
madac is offline
Old 10-11-2011 | 07:49 PM
  #68
Let me make it clear, I do not and will not follow any brand.
ownly what works gets my money, I am not a money pit. Are you?
Tim3 is offline
Old 10-11-2011 | 09:40 PM
  #69
Depending on who makes it for Bluebird it may or may not be worth a ...... They managed to leave me very disappointed in them years ago and I have refused to try again. Hoping they have their act together now and not pushing BS numbers.
Not sure why the new Hitec servo has not surfaced yet. If it is anything like their claims it will be a game changer and Hitec is closer to there specs than many out there.
bentgear is offline
Old 10-11-2011 | 10:38 PM
  #70
madac's Avatar
Let me make it clear, I do not and will follow any brand.
I know I'm not a money pit(although it would be nice if I was and I still would try the Bluebirds out before buying Hitec again) and a good cheap servo that works is better then blowing my money on an expensive servo that works the same as the cheap ones. And I will not follow any brands like others do, I can see they were the ones that believed that Y2K was real as well. I have one Hitec left(the only one not to crap out on me yet out of 6),futaba and Turnigy(these are awesome) servos that I have so I hope that shows That I will not be a brand robot. I buy what works and if the Bluebirds BLS servos are good I would take those anyday.
madac is offline
Old 10-12-2011 | 08:10 AM
  #71
bentgear I have been disappointed too with blues.
I have had Hitec crap out and the price that they are !
madac, I am with you. I'm getting the blue in about two weeks. I'll let you know how it is.
Tim3 is offline
Old 10-12-2011 | 01:09 PM
  #72
Integra's Avatar
It has been stated a couple times in this thread so far.
Integra is offline
Old 10-12-2011 | 04:00 PM
  #73
madac's Avatar
That sounds awesome I could really go for some real world evaluation of the Bluebird brushless servos, Thanks. And every company has their cheap servos including Hitec and if everyone that is saying the Bluebirds are crap which ones are they the $15-$20 or the $60-$90 ones or did you just hear it from somewhere else? I have been extremely disappointed with the crapped out Hitec ones that I have especially with their customer service!
madac is offline
Old 10-13-2011 | 07:37 AM
  #74
Integra's Avatar
Dude, Drop it. Hitec has By Far the Best customer service in the industry. You "claim" no warranty but i personally do Not believe that as I Know for a Fact how Hitec works in that dept.
Integra is offline
Old 10-13-2011 | 08:16 AM
  #75
Tim3 is offline
