Competition heat deuce question..... >
Old 10-18-2011 | 11:10 AM
  #31
houston's Avatar
Tech Prophet
Originally Posted by Honu
How many watts does the 120v Deuce consume. I'm planning to use it with my generator.
Approx. 60w .50amps
Unregulated voltage from lesser made genset units will cause unit to heat too rapidly so pay attention to that , honda , yamaha and other quality brands are regulated so no issues
houston is offline
Old 10-18-2011 | 02:15 PM
  #32
Honu is offline
Old 09-19-2013 | 01:00 AM
  #33
How much mah I need to heat the engine. Our ambient temps are always above 86F. Trying to get the required lipo. Also will low discharge be sufficient (20C)?
rcindia is offline
Old 09-19-2013 | 08:25 AM
  #34
motomatt's Avatar
a 5000mA battery will give you approx. 1 hour of heating. Higher ambient temps don't need as much preheating time.
It's wise to use a voltage alarm or voltage cut-off for Lipo batteries.
Yes, 20c is more than enough. The unit only draws 5 amps. On a 5000mA battery this is only 1c.
motomatt is offline
