Like Tree5Likes
SC10 4x4 Thread
Old 10-10-2011 | 10:14 AM
  #8341
BryanAZ's Avatar
Originally Posted by special_k
I know this question has been beaten to death, and I looked for some answers, but no one has really answered the question. So, I'll try to ask it a lil' different:t he guys that are running on a clay track, what tires are you running?
Honestly, the best answer to this question is to go to the track and see what everyone else is running. I personally like AKA products, so I would recommend either re-bars if it is a high bite track and gridirons if it is a medium bite track that tends to get a little loamy. Do they water the track or is it dry?
BryanAZ is offline
Old 10-10-2011 | 10:22 AM
  #8342
They water the track a couple of days b4 a race but it is a new track and was trying to c what the masses are running so i can have an edge lol or aleast try u no what i mean lol thanx for the info
special_k is offline
Old 10-10-2011 | 10:24 AM
  #8343
BryanAZ's Avatar
They water the track a couple of days before a race, but it is a new track and I was trying to see what the masses were running so i could have an edge, lol, or at least try; you know what i mean, lol. Thanks for the info
Sounds like it is probably a pretty sticky, high bite clay track, so I would try re-bars.
BryanAZ is offline
Old 10-10-2011 | 10:30 AM
  #8344
Thumbs up
Thanx ill try them
Old 10-10-2011 | 10:38 AM
  #8345
Originally Posted by GuiltyByAssoc
So what are the final results of the Reedy truck race?
http://www.liverc.com link wont work but it is there under Live broadcasts select reedy truck race then go to results.
mugenlife is offline
Old 10-10-2011 | 10:44 AM
  #8346
Marcus, hang in there, I'm coming LOL! Seriously, went through the same thing with the 2wd version. The "kit" setup on the original trucks was almost undrivable, was ready to pitch it first time I went to the track. You've seen how it evolved. Some good suggestions, particularly the antisquat changes and shock limiting. I think I posted before I've limited the front on every AE I've ever owned but the B4. Mine should be here today, hope to get out with it a little this weekend, then see what I want to add first. Will def need your saddle pack conversion and probably clutch discs for starters. We'll get it figured out.
cjtamu is offline
Old 10-10-2011 | 10:50 AM
  #8347
JayL's Avatar
Clay tire:
rebars: lot's of forward not much sidebite or turn-in
wishbone: nice forward and lot's of mid corner steering
Barcodes: lot's of forward, lot's of initial turn-in, lot's of stability
JayL is offline
Old 10-10-2011 | 10:52 AM
  #8348
Got it, Thanks!
GuiltyByAssoc is offline
Old 10-10-2011 | 11:21 AM
  #8349
CraigMBA's Avatar
Originally Posted by 1Fastpede
I'm going to post a step by step later today.
Thanks in advance.
CraigMBA is offline
Old 10-10-2011 | 11:36 AM
  #8350
MantisWorx's Avatar
This is the biggest problem i have. the answer? its lack of skill or care from the losi behind you. they're lines are much different than ours and it puts them in great position to pit maneuver us. the driver doesn't know how to properly follow someone into a turn. as i said before either because of lack of skill or lack of giving a crap. its not your set up. its THEM.
Post your set up im not sure that i have seen it.
Standing shocks up will allow more rotation. even thicker rear diff oil will help but that's a fine line between losing corner traction and rotation.
nothing will cure the other drivers problem. the biggest part is that they don't stop either they drive through you.
Front:
4mm RC
1.5*camber
30k dif fluid
RCshox pistons 45wt(i am changing piston specs this week)
outside arm mounted
middle tower
ride height 24mm
Rear:
0 RC
2* camber
5k (seriously want to try 15k maybe 10)
32.5 RCS pistons
outside arm mounted
middle tower
ride height 25mm
so with all of the suggestions here is what i am going to configure and test this week:
15k front dif
10k rear dif
5mm front RC
3mm rear RC
3-3 on rear toe block (more anti squat)
I am changing dimensions on the pistons this week so i am not sure what fluids i will go with but will more than likely start with 25/25
a few months ago i machined a ball center dif on my 1/10 4w buggy and it work great, since its a ball dif it will not "dif" out but will still allow some action kinda like a 30k center diff. i can easily machine one to fit this truck so i think before i pin the slipper i will try the center dif.
MantisWorx is offline
Old 10-10-2011 | 12:04 PM
  #8351
Vegatron75's Avatar
Here's some pics of my "pinning". I chewed up the pulley a little more than is needed. Pics should explain. Used a pretty beefy pin from my rc8, had to trim it down it fit within the square in the pulley.
We'll see how it works wednesday. Also a pic of my bent a-arms.
Attached Thumbnails SC10 4x4 Thread-c-list-stuff-062.jpg   SC10 4x4 Thread-c-list-stuff-063.jpg   SC10 4x4 Thread-c-list-stuff-056.jpg
Vegatron75 is offline
Old 10-10-2011 | 12:17 PM
  #8352
1Fastpede's Avatar
Looks like my instructions helped! you did it perfect. the key here is not to use a wheel pin i cut off an end of a traxxas hingepin.
1Fastpede is offline
Old 10-10-2011 | 12:40 PM
  #8353
The more things change, the more they stay the same LOL. Don't remember who said it, but that "pinned" slipper looks just like the assembly on the 2's, 3's, and RC10GT. Truck got here today. Looking forward to trying out this ORCA speedo, first time I've ever seen one in person.
On the A-arms, is it just the fronts that warp? Got gift certificates for my bday that I didnt' use buying the truck, so looks like some wheels, tires, and spare parts are in order.
cjtamu is offline
Old 10-10-2011 | 12:56 PM
  #8354
jpure009's Avatar
Is AE coming out with the 2nd pic of the Top shaft with pin hole & inner slipper hub, with the indent for the pin.....That 2nd picture, looks like it mite solve all the problems, people are having....NICE JOB!!!
I said this before, i bought 2packs of Slipper Hardware, and used the thrust washer that was machined the widest...The widest was .27mm wider then the smallest of the 3 thrust washers i have.....So with that and HD pads in&out it worked well for me. I'm hoping the RCSHOX Dual slipper will make it even better!!....I can still use alil more burst from the slipper on the CLAY track i run on....
In the 3rd pic, what is the a-arm on the Right or LEFT bent??? or both warped???
Seems like u would have to take the A-ARMS off, to tell for sure.?.
thx
jpure009 is offline
  #8355
Vegatron75's Avatar
My rear arms look ok. Some De or the wide Jconcepts wheels would be good. Spares, servo saver assy, spur gears, maybe the steering uprights. Not many spares needed. I've run my truck w/ very little problem.
I'd get the rcshox slipper pads and or the MTK clutch basket as well.
