RC10B4.1 FT/WC
Old 10-05-2011 | 01:24 PM
  #6301
Jmuck69's Avatar
Originally Posted by Chris Jarosz
LOL! Same old springs, just a not so awesome job at polishing them.
surrrrreee they are....
Jmuck69 is offline
Old 10-05-2011 | 01:33 PM
  #6302
idrummerboy13's Avatar
OH YEA, almost forgot im to lazy to look back and c how to polish them, what do you use as far as dremil tips? for k and a.e springs
they look 10x better silver
idrummerboy13 is offline
Old 10-05-2011 | 01:37 PM
  #6303
brian cox's Avatar
Originally Posted by idrummerboy13
THEY do look a little wider and kinda taller, prob just the picture or a.e doesnt want you talkin lol imjk
I was thinking the same exact thing!
brian cox is online now
Old 10-05-2011 | 01:38 PM
  #6304
Sup guys,
Just getting back in the game. Grabbed a buggy and looking forward to ripping it up.
It's been quite a while since I raced (since 04-05 and even longer since I did offroad) and I had a couple questions. I saw the cab forward style body. The Finnisher I believe it's called. I'm assuming it's for more front downforce, thus more high speed / on power steering. Does it sacrifice too much to be used on all tracks or is it now just going to be the standard?
Bob Barry is offline
Old 10-05-2011 | 02:41 PM
  #6305
Racing089's Avatar
Whats all that speed doing for you if you cant control it? in a mod class particularly you need to get those front tries down.
Racing089 is offline
Old 10-05-2011 | 03:12 PM
  #6306
916bdogg's Avatar
Thumbs up AE Is Killer Of All......
what you talking bout "WILLIS" !
Wheelies look cool and badass if your out FRONT running the fast laps and doing them !'
916bdogg is offline
Old 10-05-2011 | 03:56 PM
  #6307
YankeeFan123's Avatar
whats everyone's method to make colored springs silver? i have brown front and green rear, whats the best way to make them silver?
YankeeFan123 is offline
Old 10-05-2011 | 04:51 PM
  #6308
D-Rek07's Avatar
Well, I think they take the paint off. Then the spring steel is silver. You could probably use silver paint and paint over the older ones.
D-Rek07 is offline
Old 10-05-2011 | 06:15 PM
  #6309
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Just learned something new today. The B4.1 has a longer shock shaft than the B4 (.80 to a .71 ). What's the purpose of the longer shaft, and are there applications where the shorter shaft is still effective? I've searched the thread and found limited info.
SpraydbySprague is offline
Old 10-05-2011 | 06:19 PM
  #6310
longer shaft means more up travel and more droop which means more steering, i might be wrong, somebody will correct lol
Old 10-05-2011 | 06:50 PM
  #6311
how do you take the paint off the springs, im trying sanding but its difficult and taking up a lot of time, is there a simpler way to remove the paint?
Old 10-05-2011 | 06:53 PM
  #6312
tecniquin2001's Avatar
You are wrong, and definitely will be corrected...
You're correct, longer shock shafts will give you more droop....
Assuming that no limiters are used, longer front shock shafts will have more droop and the car will lean further back thus causing the weight to transfer to the back, creating more traction and less steering on exit.
Longer rear shock shafts will on the other hand cause for the car to lean further forward thus transferring the weight further forward and will give you more entering steering and the rear of the car will rotate faster.
Someone else colaborate further...
tecniquin2001 is offline
Old 10-05-2011 | 06:57 PM
  #6313
pimpedaccord's Avatar
Don't sand; you will remove metal and can change the rate. Plus it takes forever...
Best way is to get some paint stripper from walmart or autozone and soak them overnight. The paint will literally fall right off. The gel works the best. Just be very careful - wear gloves and soak in a metal container (it'll eat right through plastic)
pimpedaccord is offline
Old 10-05-2011 | 06:58 PM
  #6314
mxracer458's Avatar
stick them in some paint thinner,then when done dab alittle green on the bottom spring
mxracer458 is offline
Old 10-05-2011 | 07:09 PM
  #6315
D-Rek07's Avatar
Is that to know which color they are? It may be obvious but you didn't mention the brown springs.
D-Rek07 is offline
