Novak550 Ballistic sensor wire problems
I have Sc10 4x / RX8 / 550Ballistic 5.5t....
I wanted to switch to a shorter sensor wire, for a cleaner set up. I have the Brand New Novak 4inch sensor wire to replace the 6inch.
How do I remove Sensor Wire from the Novak Motor??? I started to try and now I ripped the little rubber plug/protector. It's not ripped off totally, but i don't want to go any further. The wire won't come out???
-Do I have to unscrew anything, because the end of the wire is tucked under a little lip at the end of the outside of the motor. It should slip by the lip, but I don't want to break anything or ruin the rubber protector......
HELP!!!
p.s. also...
Can I replace that little rubber protector/plug????
I hope this is correct Forum section..
THX J
HELP!!!
p.s. also...
THX J
