Novak550 Ballistic sensor wire problems
I have Sc10 4x / RX8 / 550Ballistic 5.5t....
I wanted to switch to a shorter sensor wire, for a cleaner set up. I have the Brand New Novak 4inch sensor wire to replace the 6inch. ???? How do I remove Sensor Wire from the Novak Motor??? I started to try and now I ripped the little rubber plug/protector. It's not ripped off totally, but i don't want to go any further. The wire won't come out??? -Do I have to unscrew anything, because the end of the wire is tucked under a little lip at the end of the outside of the motor. It should slip by the lip, but I don't want to break anything or ruin the rubber protector...... HELP!!! p.s. also... Can I replace that little rubber protector/plug???? I hope this is correct Forum section.. THX J |
You have to remove the rear motor cover plate then the wire will unplug.
no you don't but ok...
my sensor plug gets caught in the rubber protector as well. I just backed off the timing screws a bit to get it out easier.
| All times are GMT -7. It is currently 01:24 AM. |
