RC10B4.1 FT/WC
Old 08-18-2011 | 07:07 PM
  #5236
Registered User
Now my problem will be to see if I can find some K wheels locally
Ryno B4.1 is offline
Old 08-18-2011 | 07:09 PM
  #5237
Wild Cherry's Avatar
Good luck with that ...
Wild Cherry is offline
Old 08-18-2011 | 07:32 PM
  #5238
Jake S's Avatar
Originally Posted by racer1812
IIRC, it's been said that K wheels will fit and no mention of Losi.
AE and K run the same and Losi is the odd man out, so blame Losi not AE..
they say rb5 fronts, and 22 rears fit the conversion.
Jake S is offline
Old 08-18-2011 | 07:42 PM
  #5239
alana07's Avatar
you can also try the TQ / Team C front rims as they both use the 12mm hex mounting system.
alana07 is offline
Old 08-18-2011 | 08:04 PM
  #5240
racer1812's Avatar
Super Moderator
Then I was half right.. I don't have an issue with the current pin rear/bearing in the wheel set-up so I'll run that untill AE makes me a new car with something different.
racer1812 is offline
Old 08-18-2011 | 08:06 PM
  #5241
Asharus's Avatar
this is my plan as well
Asharus is offline
Old 08-18-2011 | 08:30 PM
  #5242
burris7555's Avatar
Has anyone cut down a SC10 chassis to make the extended chassis?
burris7555 is offline
Old 08-18-2011 | 09:23 PM
  #5243
Jake S's Avatar
4mm is all the t4 can be extended tho, well and be legal.
Jake S is offline
Old 08-18-2011 | 09:33 PM
  #5244
Jake S's Avatar
humm maybe save the section cut outta a b4 extended chassis for it hah
Jake S is offline
Old 08-18-2011 | 11:09 PM
  #5245
aeRayls's Avatar
So I'm a little pissed. I have all my parts to convert my B4 front axles into the hex set up (just used the SC10 parts) however the wheels are not out yet so I figured I would just go with the Losi 22 fronts. I have just found that the 22 wheels use a 9mm hex where the AE kit will use a 12mm hex. This takes away the point of trying to be more universal.
Have any of you run into this problem? Are the Kyosho fronts 12mm?
Rather sure that the sc10 hex axle and b4 hex axle are different. The sc10 I believe is longer.
aeRayls is offline
Old 08-18-2011 | 11:44 PM
  #5246
Jake S's Avatar
got the saw ready for the chassis that should be in tomorrow.
Jake S is offline
Old 08-19-2011 | 12:21 AM
  #5247
Matt Trimmings's Avatar
That is one hell of a saw to cut a chassis. Good luck and take it easy.
Matt Trimmings is offline
Old 08-19-2011 | 12:35 AM
  #5248
Jake S's Avatar
just checking out some numbers 22 vs 4.1 vs roar. was wierd to see that wheelbase MAX is the same in truck AND buggy 292mm in buggy 11.5" in truck (292.1mm)
roar
Wheelbase Maximum: 292 mm
b4
Wheelbase: 273mm
22
Wheelbase: 285.5mm
wheelbase; 12.5mm shorter than 22
roar; 19mm shorter (b4)
roar
t4
Wheelbase: 288mm
22t
Wheelbase: 290mm
wheelbase; 2mm shorter than 22t
roar; 4mm shorter (t4)
truck chassis is 19mm longer than the buggy, which would make the b4 "exactly" roar max, but making the buggy lazy.
t4 wheelbase is 98.6% that of the 22t.
for a b4 wheelbase to be 98.6% that of a 22, it would need to be 281.59mm
281.59mm is 8.59mm longer than a standard b4. think im shooting for a 10.5mm shorter t4 chassis
Jake S is offline
Old 08-19-2011 | 12:37 AM
  #5249
Jake S's Avatar
variable speed table saw, will be runnin on low (2800 rpm) just not very good with straight lines with a dremel, this would also make "mass production" alot more "controlled"
Jake S is offline
Old 08-19-2011 | 05:14 AM
  #5250
Jmuck69's Avatar
The B4.1 uses a different axle and front hex as compared to the SC10RS.
Jmuck69 is offline
